AirTightness without Sprayfoam
![](https://secure.gravatar.com/avatar/766e5910fd3f70c24bb09662a03b3e25?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I am searching for Airtightness strategies that are achieving 1.5 ACH50 or better.
I am also trying to avoid sprayfoam for a variety of reasons.
If you are achieving good airtightness without spray foam please comment here
or join this discussion at the JLC Building Science Forum
http://forums.jlconline.com/forums/showthread.php?t=49172
Thank You,
John Brooks
John,
Here's a link to a GBA case study house that achieved 0.7 ACH@ 50 Pa — almost as tight as a Passivhaus — using cellulose insulation rather than spray foam.
https://www.greenbuildingadvisor.com/homes/passive-house-methods-help-build-future
Almost all of the superinsulated houses of the late 1970s and 1980s — beginning with the landmark houses in Saskatoon and Regina (Saskatchewan) — achieved excellent airtightness results without spray foam. What it took was attention to detail, using gaskets, caulk, and (often) Tremco-sealed interior polyethylene "air/vapor barriers," as the detail was referred to then.
I got to 1.7 ACH50 in a SIP house I built, and that was before I'd ever seen or done a Blower Door test. I think the biggest contributor to the leakage was the band joist, which I didn't do a great job with. If I were to do that house over again, I could easily get below 1.0 ACH50 by doing a better job with the band and installing tighter doors.
Use the Certainteed Optima Blown in Blanket (BIB) dense pack fiberglass system for walls and sloped ceilings. Consider a layer of rigid foam on the exterior. Use Huber Zip Wall system. Use sill sealer and caulk under all exterior wall plates and caulk/seal gaps in exterior wall framing (consider a blower door test before sealing up to find any weak spots). Use ridid foam blockers for rim (band) joists. You should be well under your target.
The CANADIAN HOMEBUILDERS ASSOCIATION BUILDERS MANUAL covers using poly, drywall and housewrap for an air barrier.
Will,
Thanks for the suggestion.
For those who want to get the manual, here's a link for ordering information:
http://www.buildermanual.com/
