Air to air heat pumps as primary heat source in the Black Hills of South Dakota??
![](https://secure.gravatar.com/avatar/435c84e2902ff211dfd42417f9099791?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I am building a 2 unit home in Hill City, SD. It will have a 2 bedroom 1 bath apartment above a 2 car garage. 672 square feet. This will be used as a vacation home for me and my wife. On average we will be there 3 or 4 days a month. This unit will have cove heaters as backup heat. When we are not there it will have the heat set at 50 in the winter and a/c at 80 in the summer.
There will be a 720 square foot slab on grade addition behind and around one side of the garage. (L shaped). This will be a vacation rental. 2 bedrooms, 1 and 1/2 baths plus sleeping loft. Average ceiling height 10 feet. This unit will have an electric boiler in floor heat to keep the slab warm in winter. 2 inch insulation under the slab.
I’m thinking of using Mitsubishi hyper heat heat pumps for each unit. Should they be 2 separate systems? Or all on one condenser and just zoned? Will 1 head unit up and 2 down be sufficient? Maybe some well placed ceiling fans can help move the air around? Is there a better choice than Mitsubishi?
What is your experience with heating in the cold and energy consumption? Any ideas on what size units? Is going bigger better? Finally, I am pretty handy, I have been an underground sprinkler contractor for 17 years and have built 11 homes. I was planing on mounting the units myself and then paying a HVAC guy to test the lines. Any experience DIYing this install?
Thanks in advance for the advice.
Dan
