Air sealing rimfieldstone foundation from exterior
![](https://secure.gravatar.com/avatar/5200c5ab6790f3dcba5766b39b162c6f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Recently had my home air sealed and insulated by MassSave but I can still feel air coming through in places. In new builds, I see liquid flashing being applied at the foundation. My home was built ~1900. Would it be okay to apply something like Zip LiquidFlash if I can get to the exterior interface of the rim beams and foundation? Would a cheaper sealant be just as good?
How dry is your basement? Before you work the air leakage you must any water leakage.
You may find this article interesting.
https://buildingscience.com/documents/insights/bsi-041-rubble-foundations
Frankly, there is a zero percent likelihood that we would do that to our house!
As far as dryness, I've been measuring my basement humidity since December, It's stayed between 40-50% even in and after heavier rains. In the past 3 summers, I've had to use a dehumidifier 24/7 in the summer, BUT it was far from air sealed... I discovered that there is a huge leak across the entire front of the house that I'm addressing these next couple weeks. This Summer I'll be installing a HPHW and then supplement with dehumidifier that triggers on when it's above 60%.
