Air sealing options
![](https://secure.gravatar.com/avatar/cedfac46278e90eb64847a160f9376bd?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Hello,
I’m doing a double stud wall in VT – and am looking into air sealing options.
I have seen people use spray foam around windows and edges and that seems great, but also really expensive for the purpose.
I’ve read a little about kanuf ecoseal, but that seems a pro-line product, and not something that is easily obtainable.
What are some other options available? Would Prosoco Spray Wrap MVP be something that could be used in a similar fashion (seems I can order that).
Any other suggestions?
Cary,
Most builders tape their sheathing seams with Zip System tape or a similar high-quality tape, and seal penetrations and the cracks between window rough openings and window frames with a combination of tape, caulk, and canned spray foam.
If you invest a few hundred dollars in tapes, caulk, and canned spray foam, you'll get a better return on investment (in terms of future energy savings) than you will with almost any other energy upgrade measure.
