Air sealing flat roof assembly
![](https://secure.gravatar.com/avatar/29158344421dc605c6a4b6e57198d69c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I’m in CZ 3 in southern California. Retrofitting a flat roof (currently open top and bottom) that is board sheathed with balloon framed walls.
I’m planning on adding two 1″ layers of polyiso on top of the board sheathing followed by 1/2″ plywood and either modified bitumen or TPO.
The parapet wall has detailing that I don’t want to remove on the outside. I know I need good air sealing so I have a few questions.
1) Articles I’ve read here recommend a vapor barrier under the insulation. Mine needs to be an air barrier as well. A peel and stick would work but then I have no drying potential to the inside. Any vapor retarders that would fit the bill?
2) In regards to the poly-iso, if I don’t use a foil backed that should help drying to the inside but may make taping more difficult. Any thoughts?
3) I’ve considered closed cell spray foam to seal the parapet and potentially the whole ceiling but there are few contractors in this area that do SPF.
4) I’m guessing that I need to open the back side of the parapet wall and seal from above with either a peel and stick or cut-cobble poly-iso (or both?).
5) Would you insulate the back side of the parapet wall with poly-iso? If I did would that decrease my need to block and air seal inside of the parapet wall?
This question builds off of a prior one I asked:
https://www.greenbuildingadvisor.com/question/parapet-wall-air-sealing-detail
Thanks in advance for your comments. This site has been an incredible resource.
Matt
Hi Matt,
I am unsure of the need for a vapor barrier in the location that you are proposing. Is that a code requirement in your area?
There are lots of ways to theorize about how to air seal the parapet, but I have never done that work. Hopefully someone with some experience comes along with suggestions.
Also, another question: are you planning to put any more insulation in the rafter bays below the roof deck?
