Air sealing did not improve blower door test results. Why?
halaby | Posted in Energy Efficiency and Durability on
I recently air sealed and insulated my house as follows:
1) air sealed 40 recessed cans;
2) air sealed all major attic penetrations;
3) spray foamed all my basement and crawlspace sills;
4) topped up all the attic insulation to 50R
The blower door test results were the same on post-test and pre-test. How does that happen?
Alternative retest methods did not change this outcome — no improvement detected. The energy auditor could not explain it.
  1. GBA Editor
    Martin Holladay | | #1
    Charles,
    Here are some possible explanations:
    1. The blower door tests weren't performed correctly, and their results are inaccurate.
    2. Your air-sealing efforts were sloppy.
    3. Your air-sealing efforts were excellent, but there is a monstrous hole in your thermal envelope that you have not yet located.
  2. user-1115477 | | #2
    Charles,
    First, your # 4 doesn't necessarily help with air sealing.
    Also, similar to what Martin said with his #3: It sounds like your leakage is in places different from those you sealed. As surely you know, there are many other places for infiltration than those you mentioned.
  3. davidmeiland | | #3
    There is no substitute for blower door-guided air sealing. You run the fan the whole time, either pressurizing or depressurizing, find the leaks, seal them, and confirm as you go that the manometer shows a reduction. I have done pre and posts tests for crews that did not do this, and they often don't get much improvement. For that matter, I don't do much without the fan running myself.
