air sealing
Eska | Posted in Energy Efficiency and Durability on
how best to maintain air barrier at insulated ceilings when installing LED pot lights
    BILL WICHERS | | #1
    This depends a lot on what kind of LED lights you're using. If you're using LEDs in recessed cans, or any of the "conversion kits", then all the same issues apply to that recessed can as it would have before. If you're using the puck-type lights, it depends on the mounting. I like the lights that mount in 4" round electrical boxes. When I use this style of LED light, I use the white fiberglass "hard boxes", in part because they don't leak -- thay have no holes (or at least they used to not have any, more on that later). I air seal the perimeter of the box to the drywall, by cutting the hole for the box with a hole saw that leaves about a 1/8" gap between the box perimeter and the drywall. I fill the gap with canned foam using a gun and the narrow "injection nozzle" attachment (this is with the Dow foam gun). I seal the wire entry to the box with red silicone high-temp caulk, or sometimes with canned foam if I have good access to the back of the box.
    The white fiberglass boxes are easiest to air seal. If you're using a surface-mount puck light, I don't really have any hints since I haven't used those before.
    A note on the newer fiberglass hard boxes: I've noticed that the holes for the cover plate screws to thread into now go all the way through the box. I air seal those with a bit of canned foam on the backside. You can smear some caulk into the holes from the front of the box after installation too. Easy enough to do, but I didn't notice those holes now go all the way through until I happened, by chance, to see a worklight in the attic through the screw holes in a recently installed box.
