Air seal Zip to glycol pipes
estebang | Posted in Energy Efficiency and Durability on
I am putting solar water heaters on my roof.  The roof is made up of 7/16 Zip (which is my air and vapor barrier), 2 layers of rigid insulation then flat 2×4 air channel and 5/8 plywood.  I know the zip tape will not withstand the heat temp of the copper glycol pipes. It is (2) half inch pipes. I think the temp in the pipes can get up to 250 degrees.  What have others done to seal these holes?
