Air-Sealing Penetrations from Gas/Electric Lines
![](https://secure.gravatar.com/avatar/e6eca528abcc2e70a58baf9eec8a036b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
The area below the rectangle the lines emerge from is what I would describe as an ash pit. I think I can seal it below where the line come in there, but in the fireplace, I would like a solid bulkhead fitting or rubber flange to seal them the best they can be. I have looked at a variety supply website, but haven’t found what I am looking for yet. The gas line would have the 3/4 – 1/2 reducer replaced then black pipe mounted to the interior of the firebox with the shutoff at the end. The flex conduit just goes to an outlet box.
Any ideas?
Seems to me the electric wire is rated for something like 75°C so it would seem safe to fill the gap with foam insulation (Greatstuff)
I was hoping to have something that was more mechanically rigid or significantly more flexible and retentive.
You won't find a grommet that will seal into an irregular hole like that.
I would use Great stuff as Walter mentioned. If you want something a little more durable than that, use Loctite's Titefoam, which is denser and more solid than Greatstuff (and it costs more too).
If you want something rubber-like, you could possibly use elastomeric roof sealant, but I really wouldn't recommend trying that. Canned foam is really the right product to use here. If you want to limit how much canned foam you use, I'd cut a block of XPS to mostly fit the hole, then foam that block in place and foam the lines into holes in the block.
Boy, I didn't say what I should have. I plan to use a piece of metal or plastic, like cutting board material, to cover over the rectangle. Then have holes in it to allow those through. The bulkheads/ fittings would then keep things sealed up. Sorry for the lack of information. The can foam makes sense based on what I first posted. I will caulk/foam to seal the edge.
