Air Gap Beneath Roof Sheathing
![](https://secure.gravatar.com/avatar/f82d165fa8e3df5b63bd2aa316b1c542?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I am building a tiny house and have an unvented gable roof with 5/8″ ZIP sheathing above 2×6 rafters. I am planning to use Rockwool Comfort Batt insulation, but haven’t found a definitive answer on whether or not I need to leave an air gap underneath the roof assembly. If an air gap is needed, I will need to fur out the rafters 1/2″ to 3/4″. I am in climate zone 2/3 so not worried about a heavy snow load or typical northern climate issues.
Thanks!
Just following up on this... another question: Would it be better to use Rigid Foam Insulation board to fill the rafter cavity or stick with Rockwool?
I'm replying to your question to give it a bump and to suggest that you read this Q&A thread.
