Air gap between cathedral roof insulation and inner wall
![](https://secure.gravatar.com/avatar/5a2fd937a2a13ec5682494fcd6cd30f8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Hello, thanks for entertaining my question. I need to obtain r-38 in my cathedral ceiling (really an A-frame), and the rafters are 11 1/4 deep. There will be 2″ of closed cell foam against the inner roof deck. Can I leave a gap between the foam and 6″ of fiberglass and drywall? If so would I use something like simpson strong tie insulation support?
You don't need a gap and really should fill the bay to maximize the r-value of the roof (wall?) assembly. See Mike Maines article for more info: https://www.greenbuildingadvisor.com/app/uploads/sites/default/files/Why%20Flash%20and%20Batt%20Makes%20Sense.pdf.
If you leave a gap, one of the experts may be able to advise on whether this will create a bypass and whether that might be an issue.
I should clarify the gap would be from the fiberglass to the drywall, not between the closed cell foam and the fiberglass. Otherwise I need to put 11" of insulation over the foam to make it flush. Since I have 3200sf of roof/wall, that's a lot of insulation.
Gap between drywall and insulation is not an issue. With a tall wall like that you might still get a fair bit of convection, so spending a bit extra on high density batts would be not hurt.
