Air barrier for existing masonry party wall?
![](https://secure.gravatar.com/avatar/36ec234c3fa4d54304a6ca378d2b8a7e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hi. I’m wondering if anyone has any experience with spray-applied air barriers for existing masonry party walls.
I’m in Philly designing Passivehouse infills and we need a way to continuously air seal the face of adjacent brick party walls to maintain our envelope. We usually use closed cell spray foam, but it is not accepted as a reliable air barrier. Any product or method suggestions will be greatly appreciated. Thanks.
Jon,
For more information on using spray foam as an air barrier, see this article: "Air Leakage Through Spray Polyurethane Foam."
If closed-cell spray foam is installed at a thickness of 3/4 inch or more, it's an air barrier.
If for some reason you want to use a different product, a fluid-applied water-resistive barrier would work. For more information, see "Housewrap in a Can: Liquid-Applied WRBs."
