Air and moisture barriers; a general question
Other than convenience of construction is there any reason not to have the air / moisture barrier immediately behind the drywall?
I realize air sealing around electrical and plumbing penetrations may require additional diligence but if the assembly meets or exceeds full wall and roof R-value for a given climate zone, and is vapor-open to the exterior, is such an assembly system workable?
If okay I would like to try a test build with inbaord sheathing with an inboard side liquid applied barrier.
Do you have any thoughts or experience with this kind of system.
Thanks in advance.
Andrew,
Many wall assemblies have no sheathing at all, and until fairly recently the primary air-barrier was usually either the interior wall finish, or a membrane directly behind it.
Thanks Malcolm. My thought is whether it is still legit and workable from a modern building science perspective. If so, then I think cost effective yet high longevity structures could be produced this way.
Balloon frame with steel (thermastrut); box out window and door opennings and sheath the inside of the framing; air barrier on the inside of the sheathing, then drywall; wiring and plumbing can be installed either early-on from inside or anytime later-on from outside; next install six inches or more of continuous exterior insulation (loose fill is likely sufficient) and then add roofing and rainscreen siding.
That is the concept anyway. But as I am not a builder I am open to the likely possibility I am quite wrong. I thought I would try propose it anyway :-)
That assembly is going to be a pain from a rough in perspective.
I'm not disagreeing because I have never done it but what do you see causing the most difficulty? Secondly, do you think it would be a pain even if the same trades people were to do it again after their first couple of times working it out?
The plywood, and yes.
Okay, good. Thanks.
