After improvement, equivalent leakage area is worse but ACH50 is better
![](https://secure.gravatar.com/avatar/dbaeffe34c7410aa6e9e5b3c79abfb79?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fv.png&r=g)
Hi everyone,
First question on this forum. I could months ago, I did an after home improvement air leakage test. The client had done some good work to reduce leakage in is home. When I looked at the number, the result at ACH50 was better then the first time, but the EqLA was bigger.
How can this be possible ?
Thank you !
It is possible to have better results at higher pressure (50 pascals) and worse results at lower pressure (10 pascals where EqLA is derived). Or could just be noise in the measurements.
