Heat Pump Heating Seasonal Performance Factor (HSPF)
PMatt | Posted in General Questions on
Hi,
does a heat pump operating Washington DC on average perform any worse than its official HSPF rating indicates ( if properly installed, sized, charged etc).  The issue is that in cold climate the nominal HSPF rating will obviously not be achieved and it will over-achieved in hot climates . My understanding is that the nominal rating is for climate zone 4, which DC is in.  If you have reference to papers studying the issue, that would be great.  Thanks!
  1. GBA Editor
    Kiley Jacques | | #1
    Hi Matt,
    I’m giving your question a bump in hopes an HVAC expert or someone with related experience will share some thoughts.
  2. Jon_R | | #2
    Lots of info below. Being in Z4 and HSPF using a Z4 reference, I suspect that you won't have data necessary to make a much better estimate than the HSPF rating.
    https://www.aceee.org/files/proceedings/2004/data/papers/SS04_Panel1_Paper08.pdf
  3. PMatt | | #3
    Thanks Jon. My understanding is that the HSPF rating is designed for Climate Region 4, which is what DC is in. And yet our local natural gas utility runs a cost comparisons between heating with natural gas and heating with a heat pump that de-rates the stated HSPF of the heat pump in order to ostensibly account for "local climate".
