Adjustable Height Range Hood
![](https://secure.gravatar.com/avatar/18850a93704fec25b75624e94df012a1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Are there any adjustable height range hoods that can be lowered closer to the stove when in use and lifted when not in use?
I remember seeing one in a video, but can’t find it now that I’m looking for it. An adjustable height range hood would be more effective, have a higher capture rate, require a smaller/quieter fan and use less makeup air. These are all great benefits.
Thanks,
Adam
I have not seen that option. There are models that extend outward when in use, and downdrafts that rise up when in use. Maybe there are vertically adjustable hoods as well; I just haven't seen them.
Miele used to make one. Think it is discontinued but you may be able to find one NOS.
https://us.mieleusa.com/MieleMedia/docs/products/specs/pdf/hoods/DA424-6V.pdf
Here’s one
https://www.designerappliances.com/miele-da424v.html
Definitely not cheap.
Thanks all... the Miele is pricey. I'm temped to DIY one, but it would look like something I DIY'd.
It's really just the capture area that would need to be lowered, not all the components of a hood. With that in mind, I wonder if a decorative facade could be lowered while the hood itself remains in place. This depends on what's to the side of course.
