Adding Insulation to Walls
![](https://secure.gravatar.com/avatar/3d2e632f31aed608e40b5ec6e6710de4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fg.png&r=g)
I have a ranch house in Westchester County, N.Y., Zone 5, built in the late 60’s. I will be replacing the single pane windows and replacing the siding with Craneboard insulated vinyl. The house is 2×4 construction with fiberglass batt insulation and plywood sheathing. My question is that I would like to add additional insulation, and am looking for suggestions? I’ve looked at the Zip R sheathing alternatives as they seem like the easiest solution with the exterior siding and windows being removed, but am confused regarding moisture concerns.
