Adding a ventilated rainscreen
BPortnoy1 | Posted in General Questions on
Hello. I am considering removing my siding and adding a rainscreen behind. (Climate 4a) However the siding now is flush with the windows and will then have a 3/8 inch gap behind. What’s the best way to handle this? In general do my windows need to be removed and reinstalled to add a rainscreen or can I do this without.  Thanks in advance.
  1. matt2021 | | #1
    Hi! Coincidentally, I had started a discussion on a similar matter (though new construct, not retrofit). You might find answers given to my questions relevant to an extent. Good luck with the project!
  2. Malcolm_Taylor | | #2
    BPortnoy1,
    The simplest solution is to trim out the windows before adding the rain-screen, and have the siding butt up to the trim. Here is an example:
    1. BPortnoy1 | | #3
      Thank you
