Add External Continuous Insulation
![](https://secure.gravatar.com/avatar/939f4bcf03b0015ecccde187ad331515?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I have a one-year old home in Climate Zone 5A with “flash and batt” insulation in the exterior walls. My framing is 2×6, specifically (from outside to inside): vinyl siding, vapor barrier (Kimberly Clark), 2 inches of closed cell foam, R-11 fiberglass batts. I’m not a builder so it’s possible I missed something on the outside.
I’d like to add exterior continuous insulation in the future to increase the R-value of my exterior walls and reduce the thermal bridging through the studs, but also keep my existing insulation inside. My goal would be to add as much R-Value as possible (e.g. 1.5-2 inches of foam board, Zip-R, etc.). At the same time, I would likely look to upgrade at least some of my double-paned windows to triple pane.
What are my options with the exterior insulation? What do I need to consider to avoid condensation issues etc. from my existing construction? Thanks in advance for your guidance!
Randy Williams recently posted a good two-part series that should answer most of your questions:
https://www.greenbuildingadvisor.com/article/continuous-insulation-part-1
https://www.greenbuildingadvisor.com/article/continuous-insulation-part-2
Thanks. Will review.
You will want to use a vapor permeable insulation material. You don't want to trap moisture between two Class 1/low Class 2 vapor retarders. I would go with a wood fiber, mineral wool or cork.
