AC fan speed and sensible vs. latent cooling
![](https://secure.gravatar.com/avatar/830e89267ffbb55b74619896b1086012?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I understand the basic idea that a lower fan speed on an AC unit shifts the balance more towards removing humidity, and a faster fan speed shifts the balance more towards lowering the temperature.
I’d love to see the math on how this balance plays out, and have been struggling to google up a more technical explanation.
Anyone have a good link to a technical explanation of how this works? Or want to walk through a basic example with some numbers?
Thanks much!
Brendan,
Here are two links:
Why 400 CFM per Ton is used for Determining “Standard Air” Conditions Air Volumes
Sensible and Latent Cooling Load Control Using Centrally‐Ducted, Variable‐Capacity Space Conditioning Systems in Low Sensible Load Environments
