A somewhat unique shared wall, and how to insulate it.
rgbtv | Posted in General Questions on
Hi everyone, I posed a scenario a few days ago and got good feedback. However, there is one part of this setup I need some good advice on. That is the third paragraph here, this next paragraph is just some additional context.
I’m in northern New England, Zone 6. I have an addition on my house with a shed style roof, soffit vents, no ridge vent and unsure if a high vent point could work. I have it down to the studs. I will be using 4″ closed cell spray foam in ceiling with an aged R value of 30 for the full 4″. Next layer will be  R23 rockwool for added insulation and a thermal barrier. I plan on a T&G ceiling. (As an aside: While I may opt to keep the wood look on the interior, any feedback if priming the “back” of the board would be useful, perhaps with a vapor barrier primer?). I was then planning on having 3″ of closed cell spray foam sprayed in the walls until I recently read more on this site about better, cost effective, environmentally suitable options for the walls.
My real question is about an 8 foot shared wall with the partially insulated, unheated garage that is often 10 degrees warmer than outside, but can regularly be below freezing in deep winter. This wall currently has 5/8″ drywall on the addition side followed by what I think is very old asphalt impregnated fiberboard followed by the old house’s sheathing (around 1/2″ plywood). THEN there’s the 2×4 stud garage wall with fiberglass faced kraft. The kraft faces the garage. Then there’s OSB on top of this on the garage side, but hung in a very leaky manner. I don’t have plans anytime soon to heat the garage. So, I’m hoping for some feedback, given all these layers, what best practice should I aim for here? I’m willing to replace the fiberglass, I haven’t fully taken the OSB down to determine what kind of shape it’s in. Otherwise, leave as is?
Thank you for helping me clarify how to handle this wall.
  1. PAUL KUENN | | #1
    The garage is only warmer from all the leakage of the houses heat! I'd just add 2" of reclaimed EPS over the garage side wall and cover with 1/2" plywood.
