A-frame construction details
![](https://secure.gravatar.com/avatar/acccde18628d9c639a16dfcb0a31205a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Are there any resources for A frame construction details? Planning a new build in zone 5. I have a footprint, but no direction on roof framing construction, materials or insulation.
User 704etc.,
First, can you tell us your name?
Yes, there are books and web sites that tell you how to build an A-frame. Here is a link to an online resource excerpted from a book you can buy: "How to Build an A-Frame."
That said, if these construction details are new to you, you might want to consult an engineer or a general contractor for help.
If you are looking for details on insulating the roof of an A-frame, follow the advice in this article: "How to Build an Insulated Cathedral Ceiling."
Thanks for your reply, Martin.
My name is Danny Johnson. I’ll try to update my profile to display that.
I’m a residential remodeler. I have a rough floor plan drawn up by a draftsman. Construction details in general aren’t new to me, I have yet to find any current details regarding a frame construction. An online search makes it appear as though one hasn’t been built since the 70’s.
I’ve chatted about it with an engineer, a couple architects, a truss designer, etc. Lots of different ideas (lvl’s, sips, i-joists, etc.)
I was hoping someone had a recent build that would be simple structurally, allow for robust insulation and easy air sealing.
I did read the article on the insulated cathedral ceiling. The roof would be a straight shot from eave to ridge and I was planning on a site build baffle below the sheathing.
My main question was what type of framing member to use for the wall / roof and loft floor.
