A/C vs. heat pump performance
![](https://secure.gravatar.com/avatar/f7cb174131f4b8d299ff0e3df9b44e6c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
On the U.S. Department of Energy website I read “High-efficiency heat pumps…dehumidify better than standard central air conditioners…” Is this true? If so, why? The highest efficiency heat pumps I have seen have an extremely high sensible heat ratio.
Totally misleading. An apples to apples comparison between the same make/model AC and HP should show the same dehumidification performance.
