Ceiling fans are a great way to create more comfort in a room by circulating either warm or cool air to average out the temperature. When installing them, it is important to make sure the blades are balanced. While this is typically done at the factory, fine adjustment is sometimes needed. In this video Fernando Pagés Ruiz shows you how to use the balancing tool that comes along with the fan.
Video by: Gary Junken
https://www.greenbuildingadvisor.com/blogs/dept/energy-solutions/high-tech-ceiling-fans-low-tech-cooling
https://www.greenbuildingadvisor.com/blogs/dept/building-science/how-buy-energy-efficient-ceiling-fan
