Green Basics
Efficient Plumbing Supply Layouts
Home-run Layouts from a Manifold Have a Few Advantages
ABOUT EFFICIENT PLUMBING LAYOUT
Sound planning saves energy
Heat losses increase with the diameter of the line, the distance the water must travel, and inversely with the speed at which the water moves. A large volume of slow-moving water sheds more heat as it travels to its destination than a smaller amount of water moving quickly.
For that reason, zoned trunk-and-branch systems (also known as structured plumbing) save water and energy compared to conventional trunk-and-branch systems or home-run (manifold) systems.
Heat loss in conventional systems. A 3/4-in. dia. supply line in a trunk-and-branch system holds a lot of water. When a hot-water tap is opened in a bathroom far from the water heater, all the water sitting in the 3/4-in. pipe must flow through the system before any hot water reaches the user.
In a home-run system, the tubing is usually only 3/8 in. or ½ in., so less water is wasted before hot water reaches the faucet.
Structured plumbing. To reduce the time it takes hot water to reach a remote faucet, save energy, and save water, green builders should install a type of plumbing system called “zoned trunk and branch” or “structured plumbing.” For more information on structured plumbing, see these two articles:
  1. ALSHAWA | | #1
    Plumbing
    What is the best type of PEX pipes to use ?
    Which is the best price?
    Do I need to insulate PEX pipes?
    Response to Al Shawa
    Al Shawa,
    Q. "What is the best type of PEX pipes to use?"
    A. These days, PEX tubing is a fairly generic product. Although several manufacturers vie for the market, I doubt if you will find major quality differences between the different products.
    Q. "Which is the best price?"
    A. That's a question that can only be answered locally.
    Q. "Do I need to insulate PEX pipes?"
    A. Yes.
  3. user-7619767 | | #3
    Hello. We are building a new construction, high end house and want water distributed to all areas of the house to have the following: Consistent hot water. So when the washing machine is receiving hot water, somebody showering doesn't feel any effect, either from pressure or temperature. We also are planning to use tankless water heaters and a recirculating system. What is the best system design to accomplish these goals?
  • Green Basics
    Water Heating
    UPDATED 04/05/2012Tank or Tankless: Reduce the Load to Lower Water Heating Costs
  • Green Basics
    Green Remodeling Guide
    Green Remodeling Is Different from Building New, but the Goals Are the SameIn fact, remodeling an existing house is inherently greener than building a new one.#Americans spend roughly $200 billion a year remodeling their homes. The scope of these projects varies from simply repainting a kitchen to gutting a house down to the studs. What all remodels have in common is that they are upgrading rather than replacing, rebuilding rather than building new. And from an energy resources point of view, remodeling a house, rather than building a brand new one with all new materials on a previously undeveloped site, is a green thing to do.What makes a remodel green? In a nutshell, it means seeking the same objectives with a remodel as we would in new construction: energy efficiency, resource conservation, and a healthy indoor environment. You get there the same way as new construction: planning and design. Begin with a home energy audit to see where the biggest greening opportunities are, and then look for ways to roll improvements into the scope of future remodeling plans.REMODELING PROJECTS:#Kitchen | Addition | Bathroom | Energy Retrofit | Basement | Gut Rehab | Home Office | Decks/Porches | Weatherization Four steps to green remodeling
  • Green Basics
    Green Plumbing Systems Save Water and Energy
    Design the Plumbing System to Save Water and Energy
