Window Construction Details for High Performance and Energy Efficiency
Tight-fitting, leak-free windows mean comfort and energy savings
Whether building a new house or remodeling an old one, these details show proper window installation methods for ten types of exterior siding — from wood to brick to stucco — in any climate. Head, jamb, sill, and plan details along with retrofit options for shower and exterior insulation retrofit:
BRICK VENEER | FIBER CEMENT | METAL LAP SIDING | STONE VENEER | SYNTHETIC STONE
TWO-COAT STUCCO | VERTICAL BOARD | VINYL | WOOD CLAPBOARD | WOOD SHINGLE | EXTERIOR INSULATION RETROFIT | SHOWER WINDOW RETROFIT
BRICK VENEER
Exterior Foam Sheathing
FREE sample detail: Head — DOWNLOAD: PDF | DWG
FIBER CEMENT
![](https://beta.greenbuildingadvisor.com/app/uploads/sites/default/files/images/Sill-3-00007-F-Cement.gif)
Exterior Foam Sheathing with Furring Strips (Padded Opening)
METAL LAP SIDING
BECOME A MEMBER AND GET FULL ACCESS TO GREEN BUILDING ADVISOR
STONE VENEER
SYNTHETIC STONE
TWO-COAT STUCCO
VERTICAL BOARD
VINYL
WOOD CLAPBOARD
1-1/2 in. Exterior Foam Sheathing
1-1/2 in. Exterior Foam Sheathing (Padded Opening)
1 in. Exterior Foam Sheathing
1 in. Exterior Foam Sheathing with Furring Strips (Padded Opening)
3/4 in. Exterior Foam Sheathing
3/4 in. Exterior Foam Sheathing (Padded Opening)
WOOD SHINGLE
3/4 in. Exterior Foam Sheathing with Drainage Mat
EXTERIOR INSULATION RETROFIT: NEW WINDOW
High Sill — DOWNLOAD: PDF | DWG
Low Sill — DOWNLOAD: PDF | DWG
