General Questions
Attic conversion knee walls
I have a 24' x 35' attic that has roof going all the way to floor but with steep pitch. I have t&g ply for the floors, but I am…
Floor Insulation
I bought and am remodeling a house built in the 1920's with dirt floor vented crawlspace and an addition that was built in the 60's had to tear out and…
Can subfloor breathe between Quietwalk and Rmax Thermasheath polyso
Hi all,We're in Zone 5, Northern California mountains, with very dry summers and variable-humidity winters (rain/snow raises humidity).We have a dirt crawlspace which we plan to put a vapor barrier…
Ice and water shield
I'm doing a ventilated deep rafter cathedral.The main path for any drying would be in the ventilated cavity.So is there a risk to coving the entire roof in ice shield?Or…
ceiling drywall bowing up
what could be causing the drywall in a small house with an ERV that is very tight to bow up between the ceiling joists ?
Hybrid Insulation Zone 3 – Exterior vs. Interior Ratio
I'm building a new house in the Dallas TX and I want to use a hybrid insulation strategy of poly-iso and mineral wool batts, but I'm struggling to understand the…
Dew point data
Someone posted here a few months ago a site where you could get 99th percentile dew point data. Now I can't find it.Does that rig any bells?
Window jamb extensions
Hello,I have 2" RockWool exterior insulation, vertical furring strips, and horizontal furring strips and I will be using Hardie Panel on top of that. My windows are flanged and taped…
HRV without using existing furnace fan?
Hello everyone,Following the sage advice in this forum, I have done a number of green energy upgrades to my house, including sealing the house really tightly, and switching my heating…
Foam and Siding over Existing T1-11 Siding
Location Zone 3A OKC, OK. House constructed 1979. Wall details-5/8 Sheetrock-2/4 Wood Stud Fiberglass batt (Unsure if faced or not. I know areas I have demoed in interior walls separating the…
