Building Code Questions
Trying to understand Code required insulation for condensation control
When 2021 IRC raised insulation levels it did not make a corresponding increase to the condensation control insulation levels. Consequently 2021 has lower ratios compared to 2018. Does that mean…
Help finding temperature data
IRC2018 defines an insulation ratio for condensation control in unvented roofs. In note B of Table R806.5 it says, "Alternatively, sufficient insulation shall be installed directly above the structural roof…
Structural aspects of a double-stud wall
I like Lstiburek’s ideal double-stud wall with the structural wall on the interior. Durability and resilience are important to me and I think this wall is good from that perspective.…
Smart Glass Maker Opens New Plant
The manufacturer of a type of glass that can be electronically tinted has opened a new manufacturing plant in Minnesota.
using 1/2″ maple veneer plywood glued on interior walls of home can that serve as vapour barrier requirements as well to satisfy NBC?
I want use 1/2" maple veneer plywood on interior of home. Panels will be glued to studs and have laquer finish. Can this also serve as vapour barrier requirement.
Are vapor diffusion ports now required by code?
Situation: I am in climate zone 2A, building a house with an unvented, condition attic space (ZIP system wall and roof). Roof deck will have continuous exterior insulation placed on…
Fastener Pattern and Requirements for HVHZ
Adding 2 layers of 1 inch poly iso to my roof, In Southwest Florida, was looking to find out what the fastener pattern would be for the second layer of…
Zone 3-Finishing /Insulating an Unfinished Bonus Room
Hello , I am in the planning phases of insulating and finishing an upstairs (above-garage) bonus room (Zone 3- Gwinnett, GA) for an existing home and I am trying to…
Vegetative Living Roof – Load Calculations for Flat Roof Joists
We are moving slowly on construction of our PGH. I am the general contractor. The exterior is nearly complete and we are planning to install standard 4" LiveRoof modules on…
Vapor retarder for walls in climate zone 4
I have a building with wall types:1. wood frame w/ batt insulation within stud space, no ci, exterior finishes - vinyl lap siding/board and batten, stone on metal lath over…
