Hudson Passive House, in New York’s Columbia County, though only recently completed, is already familiar to Passive House fans in the region.
Last month, for example, the 1,650-sq.-ft. timber-frame home played host to 20-plus members of New York Passive House (NYPH), a New York City-based group of “Passivists” (consultants, contractors, architects, engineers, homeowners, developers, and others) who caravanned two hours north of the city to the project site in Claverack, a scenic town a few miles east of the Hudson River. Joined by several people from the community, the NYPH contingent participated in what the project’s architect, Dennis Wedlick, and other project partners called the Hudson Passive House Hard-Hat Tour, a show-and-tell event held November 13 and 14.
The three-bedroom, two-bath house also has been the subject of an American Institute of Architects/NYPH presentation, a segment on WABC-TV’s Sunday-morning feature program “New York Viewpoint,” and write-ups in print and online publications, including a recent EcoHome post that brought it to our attention.
A well-sealed envelope
So as new as it is to the landscape, the barn-like Hudson Passive House, whose 25-ft. bow-arch beams were raised in late June, has been successfully marketed into modest celebrity. Structural insulated panels were used for the walls and roof, bringing their respective R values to 48 and 54. The foundation floor is insulated to R-60 with six layers of expanded polystyrene and, on the interior and exterior of the foundation walls, extruded polystyrene.
Mechanical ventilation is provided by a Zehnder ComfoAir 200 heat-recovery ventilator, while space heating is provided by a minisplit air-source heat pump that is mounted in the wall of the loft space at the north end of the building.
The building is exceptionally airtight, even by Passive House standards. A blower-door test showed 0.149 air changes per hour at a pressure difference of 50 Pascals. Wedlick told EcoHome that construction costs likely will range from $200 to $250 per sq. ft. ($330,000 to $412,000).
The NYPH organizers apparently liked what they saw and, in a blog post about their visit in November, suggested they might make another trip to the house in the dead of winter “so we can actually experience the PH really ‘working.’”
21 Comments
Exterior Shading
I would expect that the fully glazed south wall would require exterior shading in addition to the overhang to avoid overheating. Can anyone comment on this aspect? Also I'd be interested to know what windows were used.
Thanks
Response to J Chesnut
J,
It looks like the house has windows from Serious Energy:
http://blog.seriousmaterials.com/?p=1298
That might explain the south facade -- most of the low-U-factor windows from Serious are also low-SHGC.
More on project details
NYPH's coverage of Hudson Passive House also includes a copy of the project data sheet:
http://www.nypassivehouse.org/a4.html
Glazing
Thanks for the responses. This is the glazing spec from their PH factsheet:
I can't find the terminology "g-Wert" in my PHPP manual but I am assuming this is the SHGC number.
51% is pretty high.
g-wert
J,
g-wert (gesamtenergiedurchlassgrad) is the german equivalent of SHGC.
J,
Remember that the g-Wert will be a glazing-only number, not a whole-window number.
The Serious Materials spec sheet for their 725 window series shows that their 725 casement windows can be ordered with two glazing options. One has a SHGC of 0.21, and the other has a SHGC of 0.39.
J Chesnut's comment about summer shading
J,
My thoughts exactly when I first saw the photo.
I don't think the shape of this house lends itself to 4 season solar management.
PHPP
Whether the windows "work" or the solar is "managed" is all determined in the PHPP, the computer modeling tool developed by the Passive House Institute - and an essential element in producing a successful Passive House project. If the specs work out in the PHPP modeling, AND the building is actually constructed accordingly, then the chances of the windows "working" and the solar being "managed" in the 4 seasons is very high indeed.
Intuitively large south facing glass with some overhang and almost no east/west glass, sounds like a very logical place to start. With the rest of the PH methodology of continuous insulation, elimination of thermal bridging, air-tightness and continuous low volume ventilation with high efficiency heat recovery - it seems like it should be "easy" to achieve great interior comfort and the deep energy savings that characterizes Passive House.
Also, just to note - NYPH is an affiliated chapter of the National Passive House Alliance. And on a personal note, I'm on the board of both.
Lessons Learned?
Ken,
Have you seen the comments from this blog
https://www.greenbuildingadvisor.com/homes/first-us-passive-house-shows-energy-efficiency-can-be-affordable
summertime overheating
PHPP has a tag that shows whether your building is overheating in summer, and various methods to mitigate the overheating, including shading outside the thermal envelope, night ventilation, etc.
also to note, contrary to standard thinking, you can achieve PH with a sizeable portion of north glazing.
Lessons Learned
John,
Thanks for the link - I'll ask Katrin about it - and the PHPP inputs. Shading is an important input in the PHPP. As Mike notes the PHPP shows pretty clearly if you have an overheating problem - but you do need to be very careful, as Feist noted. Still, with the PHPP one has much more control and a better sense of how the building should perform.
Hopefully many of these early projects - and many more going forward - are going to get wired for data collection. We want the data on how these buildings are performing - what is working and what isn't.
PHPP is fantastic
mike & Ken,
thank you both for the feedback.
I am a big fan of Passivhaus, Passive House &PHPP
I hope to be working with a consultant in the near future.
further discussion?
This news blog will be moving down the que soon
If anyone cares to discuss summer shading or this project further
here is a link to the Q&A section
https://www.greenbuildingadvisor.com/community/forum/passivhaus/19261/hudson-valley-passive-house
The Versatility of Hoodies: From Loungewear to Streetwear.
Sweatshirtsoffer a blend of comfort and style. Here are five must-haves from our collection that you’ll love.
Choosing high-quality skincarepersonal care products is essential for your health and grooming routine.
Elevate your rugged style with Leather bags
that complement your casual and outdoorsy wardrobe.
The Perfectscented candles
for Every Mood and Occasion.
Cotton-Blend Fabrics combine the softness of cotton with the durability and versatility of synthetic fibers, making them ideal for a range of clothing and home textiles.
The Long Sleeve collection at Elisdyes offers stylish and comfortable options for any wardrobe.
It looks like Elis Dyes offers a range of high-quality Hatsdyeing services, perfect for personalizing your accessories.
