![](http://images.greenbuildingadvisor.com/app/uploads/2018/07/24211517/LBC-main.jpg)
I spent most of a day recently in a seminar on the Living Building Challenge (LBC), a self-described philosophy, advocacy tool, and certification program for sustainable building. If people outside the industry think that existing green building programs are pie-in-the-sky and touchy-feely, put together by granola-eaters, then they are going to have to adjust their scales for the LBC. Currently in its 2nd version with a new release planned for 2012, it does have many similarities with other green certification programs, although it is in some ways both simpler and more complex than anything else in the marketplace.
Forget sustainable — how about restorative?
“Green” is often used interchangeably with “sustainable,” and neither word yet does justice as a name for what we are all working towards.
In a lecture many years ago I heard Michael Braungart discuss his problem with the word “sustainable” by asking the audience if they were asked how their marriage was doing, would they want to respond “sustainable”? He advocated for moving towards a restorative model, and this is what the LBC is doing.
Their goal is to create structures that not only have a lower impact on the environment, but change the paradigm of how we build so that those structures become restorative to our ecosystems. The creators believe that over the past 200 years we have used technology to separate ourselves from the environment and now it is time for us to reconnect with it.
Probably the key difference between LBC and all other certification programs is that certification is based on a full year of building operation instead of estimated or modeled energy and water use.
The flower as guiding principle
The LBC is broken down into seven “petals,” each with a subset of twenty “Imperatives.” Projects are separated into four typologies: Neighborhood, Building, Landscape and Infrastructure, and Renovation.
Building is the most common, covering all new buildings and any work on existing buildings exceeding minor improvements; those are covered by the Renovation typology. Landscape and Infrastructure are unconditioned projects that do not include physical structures as the primary program, although they can include park-like structures such as amphitheaters, restrooms, roads, bridges, and sports facilities. A Neighborhood includes multiple buildings in a single campus, drawing heavily on the principles of New Urbanism.
The first five petals look very similar to categories in many traditional green building programs: Site, Water, Energy, Health, and Materials. While in last two, Equity and Beauty, the LBC appears to differentiate itself, many of the imperatives push the envelope the furthest.
“Imperative” is another name for requirements or prerequisites, so familiar to those certifying green buildings. As in other programs, imperatives are required, except for certain exceptions, based on project type. For example, Neighborhood and Building typologies require that all imperatives be met. Landscape and Infrastructure are exempt from four and Renovation is exempt from seven.
Finally, LBC classifies projects in one of six “Transects,” a variation on those created by New Urbanism. They include Natural Habitat, Rural Agriculture, Village, General Urban, Urban Center, and Urban Core. Each of these transects affect the specific requirements of each imperative. For example, one imperative requires including food production on site, with the portion of the site devoted to this agriculture ranging from 80% in the Rural Agriculture transect to 0% in the Urban Core.
You say prerequisite, I say imperative
What appears to be the simplicity of the LBC is the list of 20 Imperatives which (with certain exceptions as mentioned above) must be met for certification. There are no points to add up nor different levels of certification (although partial certification is now available); you either make it or you don’t. This does, at first glance, appear simple, but there are many exceptions and interpretations of imperatives. These serve to both make the program more accessible to ambitious projects that otherwise wouldn’t meet certification as well as to make it more complex that it first appears.
I won’t list all 20 Imperatives in this article — you’ll have to go to the LBC website for that — but I will review some of the key ones, and how they are interpreted. In my mind, the most important imperatives are #5, Net Zero Water, #6, Ecological Water Flow, and #7, Net Zero Energy.
Net zero water means just that — the project must have a closed-loop water system that uses rain and wastewater for all potable and non-potable water on the site. Interesting exceptions to this lofty goal include drilling an on-site well, or, if after submitting a complete water capture and reuse design to the local jurisdiction you are turned down, a project is allowed to use an outside water source.
Ecological water flow is sort of the opposite of net zero water. All storm and sanitary discharge must be managed on site. No physical connection to a municipal sewer system is allowed. If the codes require a sewer connection, you must install a valve so you can disconnect after project is completed. Options to meet this imperative include installation of a septic system or an on-site sewage digester.
Finally, Net Zero Energy means what it says (including no combustion equipment allowed in the project); however it is more rigorous than the common definition. Renewable power must be generated on-site, not purchased from a local utility. Exceptions for this imperative include fuels cells powered by hydrogen created from electrolysis, recreational fireplaces in certain institutional projects, and biogas created on-site used for cooking fuel.
Slow and steady
To date, there have been three buildings certified as Living Buildings, one residential project Petal (partially) certified, and several projects in their first year of occupancy phase.
My biggest concerns with the program is that there is, at this point, very little guidance through the process, although they are starting to offer consulting to project teams, and a lack of attention to the actual building process. We were told of one of the certified projects that had much higher than projected energy use during the occupancy phase. Investigations showed that there was missing insulation in several key areas, which, when corrected, resulted in the building meeting its goals. It sounds like the team may have had more ambition in taking on this program than actual high-performance building experience.
At the end of this seminar, I definitely had a much better understanding of the LBC, and certainly appreciate the effort that has gone into developing this program. As was stated at the beginning of the day, their goals are to inspire and change the building paradigm, something that they are working hard to do.
The LBC looks as much like a political movement as a building certification program. Their impact will most likely be limited for the foreseeable future, but it will be interesting to see what influence they have on design and construction over the next few generations.
i think there are some things
i think there are some things that LBC does very well - including site and water petals. alas, equity has nothing to do with social equity - which i think would also make it a better standard.
however, i have two issues w/ LBC:
1. i don't think the energy issue is stringent enough. it's site net zero, not source - and site net zero PV isn't emissions neutral - more energy must be produced than consumed annually to be CO2 neutral.
2. outside of single family housing, the requirement for 100% renewable energy on site isn't feasible for several building typologies (like hospitals) or without expensive equipment that would have better effects at CO2 mitigation through other means. by this i mean, the cost increase to achieve net-zero energy is better expended through other (by other, i mean collective) means.
on a local LBC project, there seemed to be a circuitous path, whereas to afford PV needed for site net zero - additional tenant space needed to be added, which added more loads, which required more PV, which didn't fit within the lot lines - which resulted in a lawsuit. end result being a project billed as 'the most energy efficient commercial building in the world' - that couldn't even meet passivhaus, even at a whopping $575/sf construction cost!
yet this site net-zero bad boy in switzerland does meet PH (which means it has a lower EUI...), and cost significantly less at ~$167/sf...
http://www.minergie.ch/tl_files/download/Artikel_Erstes_Nullenergie_Buerogebaeude_der_Schweiz_energiefachbuch.pdf
How about we forget the silly names?
Nice article Carl. Just another reason to forget the silly names, and just build great homes.
How about less than $120 per square foot, for a home that will power your car as well as your house? No fossil fuels. Less than half the water use of a "normal" home. 100% storm water recharge (in clay soils). Balanced air-handling, all fresh air filtered before entering the house. All re-usable components.
Sound too good to be true? We are doing it right now! It is repeatable, and we are repeating it. Just Do It!
