Try this little perceptual experiment now: look at yourself in a mirror (or your computer or phone camera). Then look at your left eye, and then your right eye, and then back and forth several times. What do you see?
If someone else is around, ask them to look at you, and look back and forth between your eyes.
What do you see? When you’re looking at someone else moving their eyes back and forth, that’s exactly what you see. But when you look at yourself in the mirror, you never see your eyes move. When I do this, I can see that my eyes are at a slightly different angle, and I can feel a tiny break in the string of perception when moving them, but I can never see my eyes move.
Why not? The best explanation that I have heard (and please email me if you have a better one) is that while we think of our experience as an uninterrupted “movie,” that movie is actually composed of many tiny “clips,” and our brains very often fill in missing details between clips. In this case, our brains are unable to see our own eyes moving while they are moving, so the short gap in perception is smoothed over as we watch the “movie.”
It’s time to check windows for winter-readiness
With the weather this hot, it’s hard to imagine that we would ever want to try to keep it in the building. (If you’re still more focused on keeping heat out of your windows, check out last week’s post.) But check your memory from January or so, and you may realize that we can’t skip over a whole season, and that now is the time to get ready for this winter by checking your windows and seeing if any modifications can help them keep you warmer when the time comes.
Winter window attachments use one of two methods to keep heat in: adding insulation to the window assembly, or improving airtightness.
Boosting window R-value is not that hard with kits
If you’re stuck with single-pane or other poorly insulated windows, there is hope: you can boost their R-value and slow down air leakage by covering up the whole window assembly with another layer of plastic or glass. The best products perform almost as well as high-end replacement windows and tend to have a lower price tag.
A box of clear plastic and double-sided tape is the least expensive and most widely available window attachment — and the performance isn’t too shabby. These kits, commonly found at hardware stores, provide modest insulation (adding an R-value of about 1), significantly reduce air leakage, and improve comfort by adding a layer between cold glass and warm rooms. They also help prevent condensation, and both renters and homeowners can install them cost-effectively.
Insulated shades add up to R-4, but watch your seals
If you don’t like to look at the film kits, or if you don’t like loosing paint when you take them down, you might prefer the benefits of conventional fabric window coverings and interior shades, which increase comfort by adding a warmer layer between the cold window glass and the heated room.
Conventional insulated shades improve R-value by 1–2, but higher-performing shades with side tracks improve R-value by up to 4! These products include cellular shades and “window quilts” that fit snugly to the window trim with side tracks or other fasteners. The shades need to be completely closed in order to provide the full thermal benefit.
If you have insulated shades and double-glazed windows, be careful in the summer. If insulated shades are deployed on a hot, sunny day on south- and west-facing windows, preliminary research indicates that overheating may occur: some modeled temperatures have gone above 200° F (93° C), which could damage seals and shorten the expected window life. Finding other ways to control glare and solar gain on south-facing low-e windows, such as awnings or conventional curtains, is probably a good idea until more is known.
Interior window panels offer several benefits
Fixed interior window panels (widely called “interior storm windows” even though they do not protect windows from the weather) offer unobtrusive high performance starting at a relatively low price and are especially popular in places where exterior storm windows won’t work — in historic homes, condominiums, long-term rental properties, and on dangerously high windows.
They are made of plastic or glass — sometimes even low-e glass, which costs more — and come with different framing materials (most commonly aluminum). Some have operable parts and can remain in place year-round, but most have to be removed seasonally; this is the main drawback of interior panels, as they can block emergency exits through the window and also require space for safe storage.
Low-e interior window panels offer a number of benefits when properly installed. They improve R-value by about 2, increase comfort by creating a barrier between the cold window glass and the room, and do a pretty good job of sealing air leaks; the tight seal on the interior also helps reduce condensation by preventing warm, moist indoor air from entering the window assembly and being chilled by the air near the cold glass. Low-e versions have a radiant barrier that further reduces heat loss, bringing the entire window assembly almost up to par with low-e double-pane replacement windows.
Costs will vary hugely
As with window attachments for keeping heat out, costs of window attachments vary hugely. Film kits are cheap, while other options go up in price — but are often less expensive than replacing a window that’s not working for you. Check WindowAttachments.org for some great fact sheets on individual options and comparative costs. My colleague Peter Yost also offers a really insightful case study on getting the most of the windows in his house.
With my other colleague Paula Melton, Peter authored Making Windows Work Better, the recent feature article from Environmental Building News, to which I owe a lot of today’s advice.
Do you have windows that aren’t quite working for you, but you aren’t quite sure how to handle them? Other questions or comments? Post them below.
Tristan Roberts is Editorial Director at BuildingGreen, Inc., in Brattleboro, Vermont, which publishes information on green building solutions.
Also in this series:
Windows, Shades, Blinds, and Awnings
5 Comments
Good for new construction too!
With the cost of high performance windows arguably not commensurate with the value delivered in energy savings, interior storm windows (for condensation control) combined with insulating shades (for privacy) can bolster the insulating power of even pretty-good windows. I believe well-made, durable windows in the U .35 range coupled with interior storms and insulating shades will perform better than any comparably priced window. Until R-15 windows are commonplace, we should be pursuing alternatives that are affordable and higher performance.
A north facing double paned entryway window question
Hi there
I have a 5 yr old colonial just north of Manhattan NY and have a 36sq ft Anderson 400 series window (guess without pulling out the huge ladder and checking the etch in the glass) over the entryway and while its double paned still feel drafts, so I was reading your article and was wondering if I had a interior panel made up (low e maybe)m I can resolve some of these drafts and maybe cut my gas bill as well (it would be permanent as its 20ft off the ground)
So any ideas and maybe suppliers who could make it would be great
Thanks
Darren
See photo attached
Response to Darren Finch
Darren,
If your problem is really air leakage, then the solution is to track down the air leaks on the inside of the window and to seal them with high-quality caulk.
However, your problem might have nothing to do with air leakage. The cold drafts you feel might actually be due to interior convection loops rather than air infiltration. (If the glass is cold, interior air near the glass cools and drops to the floor, setting up a convection loop.) The cold feeling from this convection current is made worse by the radiational cooling that occurs when your warm skin loses heat to the cold glass.
The solution to these problems is to add a storm window or to replace the existing window with a triple-glazed low-e window. You can call up a local storm window dealer for advice; your window is very large, which may complicate installing a storm window.
"improve comfort" is mentioned a few times. I believe that means a reduction in convective transfer- something that isn't measure simply by an R value. There isn't a citation for plastic wrap being R-1, but in my experience it seems to have a bigger effect than that. Although if a window is R-4 then adding an additional R-1 is in of itself a significant boost.
I connect plastic wrap to the frame around the glass of the top of a double hung window. There's only a fraction of an inch air gap but the difference is easily felt to the touch on a cold winter day.
Improved comfort near windows usually means radiative heat transfer but it can also mean convective heat transfer--aka, drafts. Typical existing windows are R-1 or R-2, so adding R-1 cuts heat loss by 25% to 50%. I don't have a source but have heard many times that each pane of glass or plastic (or more specifically, the air space created) adds about R-1, and you can boost that with atomized metallic coatings.
