When I was doing research for an article on ceiling fans a while back, I noticed that fans don’t have energy efficiency ratings; they have efficacy ratings.
There’s certainly confusion about the terminology among different sources, but since light bulbs are also described by their efficacy, I started wondering about the term. I’d just accepted it before, with a vague understanding that there was something different about how efficacy was defined. Now I know why.
How much bang for your buck?
Here’s the deal. Efficiency in general is defined as output divided by input. It’s a number that tells you how much bang you get for your buck.
By itself, though, that definition doesn’t distinguish between efficiency and efficacy because the latter is also a bang-to-buck ratio. Here’s the difference: An efficiency rating has an energy value in both the numerator and denominator, whereas an efficacy rating has an energy value in the denominator but something else in the numerator.
Take a look at furnace efficiency, for example. The official efficiency rating is called Annual Fuel Utilization Efficiency, or AFUE. It’s the number of BTUs of heat that can be delivered to the heated space divided by the number of BTUs of heat that result from burning the fuel. A typical furnace might have an input rating of 80,000 BTU per hour and have an AFUE of 80. That means 64,000 BTU of heat per hour get delivered to the house.
Efficacy is different but the same
You put a certain amount of energy in, and you get a certain amount of energy out. We’re talking about energy output as well as energy input. That’s efficiency.
With ceiling fans and light bulbs, however, you put energy in and get something else out. With fans, the output is the air flow rate, measured in cubic feet per minute. The rating that you see on ceiling fan boxes now shows cfm per watt.
With light bulbs, you put energy (watts) in and get brightness (lumens) out. Look for the ratings on light bulb packages, and you’ll see lumens per watt.
In both of these cases involving efficacy, the type of output chosen (air flow rate or lumens) makes more sense to look at than does energy. With heating and cooling, it makes more sense to talk about efficiency because we want to know about the energy output, and we can measure it relatively easily.
Now you know the difference. You can use the word “efficacy” and look smart. And you’ll look even smarter when someone asks why you’re using that word instead of efficiency.
Efficacy of lights gets complicated.
Lumens/watt or even high CRI (color rendering index) on a light bulb doesn't necessarily an improved efficacy. Visual acuity requires some amount of overall luminosity (the lumens you get out of a bulb), but is undercut by "glare", the technical definition of which is the contrast between a bright spot in the visual field relative to its surrounding background.
In a high glare environment such recessed lights with high-efficiency LED spot light bulbs the total ambient luminosity required for visual acuity can be many times higher than it would be in a zero-glare environment, such as uplighting coves or wall-washes illuminating the ceiling/wall, using the texture of the building surfaces at a diffuse source of light.
This can be true of task-lighting as well. A common mistake people make with under-cabinet kitchen lighting is to place the fixture near the wall, directed toward the room, which puts the light further away from the front of the counter where the work is being done, and directing it at your eyes, for maximum glare, and introduces shadow artifacts from your hands. Placing the fixture at the front of the cabinet and directing it at the wall puts more light directly at the work, and fills in the shadows with the diffuse light scattering back from the wall, and eliminating the glare factor of a naked bulb/tube within the visual field.
