This construction site video of the Karuna House in Yamhill County, Oregon, demonstrates installation of a geofoam foundation that will superinsulate the bottom of the building envelope and help the project achieve Passive House and Minergie-P-ECO certifications.
Lead Carpenter Scott Gunter narrates the process of:
- screeding out gravel,
- back dragging with rake as needed,
- compacting gravel,
- marking outside foundation wall line on foam,
- setting and aligning geofoam, and
- drilling and pinning geofoam into place.
The Karuna House is designed by Holst Architecture and built by Hammer & Hand.
For more information on this topic, see Foam Under Footings.
Installing rigid foam under a footing in Yamhill County, Oregon
Karuna Passive House – geofoam foundation installation with Hammer & Hand’s Scott Gunter from HammerAndHand on Vimeo.
4 Comments
What psi foam is used? It
What psi foam is used? It would be nice to see how they build the footer forms, etc, as well.
Foam PSI
John,
Thank you for checking out the video. Under the footings we are using 2.40-2.50 lb/ft3 EPS39 (Geofoam title) or Type XIV (EPS title). Under the slab we are utilizing 1.35 -1.50 lb/ft3 EPS22 or Type II.
More info can be found on the project website: http://hammerandhand.com/_blog/Field_Notes/post/Passive_House_construction_time-lapse_a_mountain_of_foam,_delivered/
Hopefully by next week we will have a video of the next steps in the process. Our intent is to document the project each step of the way.
Critters
Is my concern of ants, termites or critters living in this amount of insulation founded?
We have done foam panel foundations, but wrapped the foam in 65mil EPDM. I was still a littler nervous about something getting in.
I wonder if building an uninsulated foundation system is more prudent and then superinsulating inside the basement or on top of a slab and decking over that. I don't know but wonder if it makes sense.
Two Big Reasons for "Outsulation"
Tom,
Insulating the outside provides at least two hidden cost savings, in addition to adding beneficial thermal mass:
1. The concrete can be stained and polished for a durable, almost free floor surface.
2. Insulating the outside and applying Frost-Protected-Shallow-Foundation principles, the thickened edge slab can be only 16" deep throughout the US.
