Article
Studies of moisture in walls with exterior foam
These two articles were highlighted recently by John Straube. Although these papers are not recent, they are relevant to a recent question raised in GBA’s Q&A column.
Effect of Foil-faced Foam Sheathing on Wall Moisture – EDU.pdf
Foam exterior sheathing – ASTM.pdf
