![](http://images.greenbuildingadvisor.com/app/uploads/2018/07/24231236/Sanden%20HPWH%20-%20whywait%20dot%20com%20dot%20au%20-%20cropped-main-700x884.jpg)
Image Credit: www.whywait.com.au
Heat-pump water heaters are a type of air-to-water heat pump. Almost all heat-pump water heaters sold in the U.S. extract heat from the air in the room where the water heater is located, transferring the heat to water in an insulated tank.
In Japan, heat-pump water heaters are configured differently; they have an outdoor compressor rather than an indoor compressor. (The outdoor units of these heat-pump water heaters resemble the outdoor units of a ductless minisplit.) This type of air-to-water heat pump is called a “split system” heat-pump water heater; it is designed to extract heat from outdoor air rather than indoor air.
The main advantage of locating the compressor outdoors is that these water heaters don’t lower the temperature of the indoor air during the winter. If this type of air-to-water heat pump has a large enough capacity, it can be used not only for domestic hot water, but also for hydronic space heating.
The Daikin Altherma
A few models of split-system air-to-water heat pumps are available in the U.S.; perhaps the best known of these appliances is the Daikin Altherma. Daikin manufactures Altherma units that have a large enough capacity to provide space heating as well as domestic hot water.
While Daikin Altherma units generally perform well, they have a few disadvantages:
15 Comments
service
I have not had a heat pump die in service yet, but most modern units I thin would not get serviced aside from a relay or board
CO2 is a common welding gas so I do not think that long term CO2 units would have a service issue
I'ts a chicken & egg thing...
CO2 is cheap & available, but refrigeration techs in the US have no training or experience with CO2 refrigerant systems, nor do they have the necessary equipment. CO2 refrigerant systems operate at a much higher pressure than HVC or CFHC systems, and the CO2 is never in liquid form during any part of the refrigeration cycle- it's an always gaseous system. It's just different from the paradigm that precedes it.
I'm sure 95% of the reefer-techs out there could learn how to deal with these heat pumps in under a week, but until there's a reason to buy the tools & get the training, so for the time being it will be a specialty skill.
I'm personally pretty happy that small CO2 heat pumps have finally made it to the US. They have more than a decade of experience with the EcoCute systems in Japan, and coming onto a decade for similar systems in Europe. CO2 is a much more environmentally benign refrigerant than any HFC or HFO solution.
Sanden's CO2 refrigerant connections
Sanden's refrigerant systems are a "packaged" system sealed at the factory...the tech does not make any refrigerant connections. The connections that bridge the "split" between the water tank and the outdoor unit are all plumbing (water).
In theory, with quality control at the factory the sealed refrigerant system should be a non-issue over the life of the outdoor unit...similar to refrigerators, window AC units and our current crop of heat pump water heaters....of course, we've seen some major issues over the past couple of years with refrigerant leaks in a couple of different heat pump water heater models (namely the first gen. GE and the AirTap units, both of which were supposedly made in the same factory. GE seems to have the issue under control now that they've developed their own unit and moved production to the U.S. The AirTap units are still a question mark in my opinion).
Response to Keith, Dana, and John
Thanks to all three of you for your comments.
The fact that the connections between the outdoor unit and the insulated water tank are all water connections is reassuring. There is a good possibility that these Eco Cute water heaters will prove to be as dependable as refrigerators.
Response to Martin
Yes, there's a good chance they'll be as dependable as refrigerators....as long as they don't add on an ice-maker to the outdoor unit.
Ice maker indeed!
As I understand it, it's the ice-up potential of the water connections between the outdoor unit and tank that limits the operating temp of the Sanden version of EcoCute to +14F, a limitation of their anti-freezing design. If used for space heating only it's likely that it would still do OK at sub-zero with a bit o' glycol in the water (albeit at somewhat reduced heat transfer efficiency on the water side of the heat exchanger in the outdoor unit.)
Sanyo's (discontinued) heating/hot-water combi EcoCute w/CO2 refrigerant had a specifed output & efficiency at -20C/-4F (see the second page):
http://www.esru.strath.ac.uk/EandE/Web_sites/10-11/ASHP_CO2/data/sanyo2009.pdf
sanden
It looks like the sanden unit is available in the US now. http://www.sandenwaterheater.com/resources/
I haven't found a price.
I'm pretty sure most of the these unit the CO system is precharged, pre-ready. On site you're only hooking up the water heat exchanger. See also https://www.ecohome.net/guides/2197/heat-pump-water-heater-with-exterior-compressor/
Thus the HVAC tech training is much less of an issue.
Well Sanden gave up apparently.
Kevin, can you elaborate? I am doing a rehab/conversion to radiant heat in Portland, OR and am just now looking into the Sandens instead of what we'd originally planned: a tankless gas combi-boiler.
The old link was dead so I thought they pulled out of the US market. All the distributors are out of stock, however, and at $4500 they might be too expensive.
The new US distributor is Eco2 systems--same people under a different organizational structure. They don't have stock because they are in the transition from Gen 3 to Gen 4 units. The web site says they expect stock in the US warehouse the last week of January, 2021: one month from now.
https://www.eco2waterheater.com/g4availability
Thanks, Kevin and Charlie.
I'm going to have main-floor staple-up radiant and basement in-slab radiant. Discussing with Tad Everhart (featured in the article) whether the Sanden might make sense for my situation.
I had planned separate zones for those floors but Tad's initial thought is that if I run high-temp through the staple-up and return it through the basement slab, that might achieve a sweet spot of appropriate heat for each area and sufficiently cooled water returning to the tank.
That sounds like a clever design that would use the Sanden efficiently. My question would be whether it leaves you with any way to tune the relative heating of the two spaces. Maybe if there is a valved bypass for each, you can partially bypass whichever is too hot? You could even do that with zone valves to allow automatic control.
For 2018 Washington State Energy code, one can get 2.5 out of 6 required credits for using this type of water heater. Unfortunately, Sanden is the only option I can find, as a sales rep just told me the Daikin Altherma is not sold in the US, as it focuses on European market.
I am waiting on pricing from a local distributor, but my main concern is serviceability as mentioned earlier. Has anyone used this for domestic water heating only?
Seems like a lot of money, and the hybrid heat pump water heaters are so efficient, odd that the state is pushing for this type of system. I suppose their concern is the hybrid heat pump water heaters give off coolth, increasing the heating loads in the winter. I was just going to have it in my unconditioned garage...
