With common-sense wiring and the right hardware, you can replace an existing light fixture with a breeze in almost any room in the house
A ceiling fan improves a room’s climate and its overall appearance, and the units are fairly easy to install– all good reasons why retrofits are so popular. Written by an electrical contractor, this article discusses the important aspects of a ceiling-fan retrofit: namely, using fan-rated outlet boxes and checking the existing wiring, as well as other installation tips.
