Researching Energy Retrofits in the Northwest
By monitoring two identical side-by-side homes, DOE researchers aim to measure the effectiveness of a variety of energy efficiency improvements
Image 1 of 2
Cutting a ribbon (and energy use). Pacific Northwest National Laboratory celebrated the launch on November 15 of a research project that will measure how retrofit technologies affect the performance of one of these two identical 1,500-sq.-ft. homes. One home will serve as a control, the other will be retrofitted in stages and its performance monitored.
Image Credit: Pacific Northwest National Laboratory
The Tri-City Region in southeastern Washington is semi-arid, with 7 to 8 inches of precipitation annually. Winter temperatures can drop into the mid-20s, while summertime highs can top 100°F.
In its newly inaugurated Lab Homes project, the Pacific Northwest National Laboratory has tried to make it easy to accurately measure the effects of energy efficiency retrofits.
Rather than relying on modeling data based on imaginary reference homes of comparable size, Lab Homes focuses on the performance of two factory-built 1,500-sq.-ft. doublewide homes set up side by side on the PNNL campus in Richland, Washington. Both homes have been tested for airtightness, duct leakage, and, using infrared imaging, thermal performance to make sure they are as close to identical as possible.
One of the buildings, dubbed the Baseline Home, “is typical of existing homes in the Inland Northwest” and will serve as a control, the PNNL explains on web pages devoted to the project.
The other building, the Experimental Home, will be retrofitted to improve energy efficiency, lower the rate of water consumption, and improve the home’s indoor air quality. The first experiment will involve the installation of high-performance R-5 windows.
The research also is expected to include evaluations of programmable appliances and car-charging stations, heat-pump water heaters and energy-efficient HVAC appliances, more insulation in the envelope, and installations of solar hot water and photovoltaic systems. Occupancy of both homes will be simulated.
A different set of comparisons in Tennessee
PNNL, a research arm of the Department of Energy, is not the only DOE entity studying residential energy efficiency. In Tennessee, four partnering groups — Oak Ridge National Laboratory, the Tennessee Valley Authority, an East Tennessee builder, and an architectural firm — teamed up in 2009 to form what is known as the Zero Energy Building Alliance, or ZERBRAlliance.
ZEBRAlliance’s principal project is a set of four 2,800-sq.-ft. model homes, each with a different building envelope. One is constructed with structural insulated panels. Another features 2×6 studs, 24 in. on center, and OSB sheathing coated with a liquid-applied water-resistive barrier (WRB), R-21 flash and batt insulation (spray foam plus fiberglass batts), a TechShield radiant barrier in the attic, and R-49 cellulose insulation on the attic floor.
The exterior walls and attic floor of the third home feature cellulose-laced phase-change material and are covered with reflective Tyvek and a Delta-Dry dual-ventilated polyethylene membrane. The fourth home features a 4-in. exterior insulation finishing system (EIFS) and a trowel-applied WRB over 2×4 walls.
ZEBRAlliance celebrated the completion of the four homes, which offered similar amenities beyond their structural enhancements, in September 2010. Data collection on that project continues.
  1. user-939142 | | #1
    is the cellulose laced with
    is the cellulose laced with phase change material an 'experiment'? ie not an actual product?
    any links or notes on what type and the ratio of PCM included?
    Response to Bob Coleman
    Bob,
    It's an actual product:
    http://www.advancedfiber.com/dynamicci.pdf
  3. AAC_NC | | #3
    It's been almost a decade since the ZERBRAlliance project began (?) and my Google must be broke because the only mentions I can find of it are here and FHB. Did it fold? The alliance partners didn't even put up a news release about it? This would seem to me to be fabulous data... if it exists.
