![](http://images.greenbuildingadvisor.com/app/uploads/2018/07/24191736/gas%20blog-main-700x467.jpg)
Image Credit: Bilfinger / Flickr
By ANTHONY J. MARCHESE and DAN ZIMMERLE
Natural gas is displacing coal, which could help fight climate change because burning it produces fewer carbon emissions. But producing and transporting natural gas releases methane, a greenhouse gas that also contributes to climate change. How big is the methane problem?
For the past five years, our research teams at Colorado State University have made thousands of methane emissions measurements at more than 700 separate facilities in the production, gathering, processing, transmission, and storage segments of the natural gas supply chain.
This experience has given us a unique perspective regarding the major sources of methane emissions from natural gas and the challenges the industry faces in terms of detecting and reducing, if not eliminating, them.
Our work, along with numerous other research projects, was recently folded into a new study published in the journal Science. This comprehensive snapshot suggests that methane emissions from oil and gas operations are much higher than current EPA estimates.
What’s wrong with methane
One way to quantify the magnitude of the methane leakage is to divide the amount of methane emitted each year by the total amount of methane pumped out of the ground each year from natural gas and oil wells. The EPA currently estimates this methane leak rate to be 1.4% — that is, for every cubic foot of natural gas drawn from underground reservoirs, 1.4% of it is lost into the atmosphere.
This study synthesized the results from a five-year series of 16 studies coordinated by environmental advocacy group Environmental Defense Fund (EDF), which involved more than 140 researchers from over 40 institutions and 50 natural gas companies.
The effort brought together scholars based at universities, think tanks, and the industry itself to make the most accurate estimate possible of the total amount of methane emitted from all U.S. oil and gas operations. It integrated data from a multitude of recent studies with measurements made on the ground and from the air.
All told, based on the results of the new study, the U.S. oil and gas industry is leaking 13 million metric tons of methane each year, which means the methane leak rate is 2.3%. This 60% difference between our new estimate and the EPA’s current one can have profound climate consequences.
Methane is a highly potent greenhouse gas, with more than 80 times the climate warming impact of carbon dioxide over the first 20 years after it is released.
An earlier EDF study showed that a methane leak rate of greater than 3% would result in no immediate climate benefits from retiring coal-fired power plants in favor of natural gas power plants.
That means even with a 2.3% leakage rate, the growing share of U.S. electricity powered by natural gas is doing something to slow the pace of climate change. However, these climate benefits could be far greater.
Also, at a methane leakage rate of 2.3%, many other uses of natural gas besides generating electricity are conclusively detrimental for the climate. For example, EDF found that replacing the diesel used in most trucks or the gasoline consumed by most cars with natural gas would require a leakage rate of less than 1.4% before there would be any immediate climate benefit.
What’s more, some scientists believe that the leakage rate could be even higher than this new estimate.
What causes these leaks
Perhaps you’ve never contemplated the long journey that natural gas travels before you can ignite the burners on the gas stove in your kitchen.
But on top of the 500,000 natural gas wells operating in the U.S. today, there are 2 million miles of pipes and millions of valves, fittings, tanks, compressors, and other components operating 24 hours per day, seven days a week, to deliver natural gas to your home.
That natural gas that you burn when you whip up a batch of pancakes may have traveled 1,000 miles or more as it wended through this complicated network. Along the way, there were ample opportunities for some of it to leak out into the atmosphere.
Natural gas leaks can be accidental, caused by malfunctioning equipment, but a lot of natural gas is also released intentionally to perform process operations such as opening and closing valves. In addition, the tens of thousands of compressors that increase the pressure and pump the gas along through the network are powered by engines that burn natural gas and their exhaust contains some unburned natural gas.
Since the natural gas delivered to your home is 85 to 95% methane, natural gas leaks are predominantly methane. While methane poses the greatest threat to the climate because of its greenhouse gas potency, natural gas contains other hydrocarbons that can degrade regional air quality and are bad for human health.
Inventory tallies vs. aircraft surveillance
The EPA Greenhouse Gas Inventory is done in a way experts like us call a “bottom-up” approach. It entails tallying up all of the nation’s natural gas equipment – from household gas meters to wellpads – and estimating an annualized average emission rate for every category and adding it all up.
There are two challenges to this approach. First, there are no accurate equipment records for many of these categories. Second, when components operate improperly or fail, emissions balloon, making it hard to develop an accurate and meaningful annualized emission rate for each source.
![](https://beta.greenbuildingadvisor.com/app/uploads/sites/default/files/images/methane_graphic.jpeg)
“Top-down” approaches, typically requiring aircraft, are the alternative. They measure methane concentrations upwind and downwind of large geographic areas. But this approach has its own shortcomings.
First, it captures all methane emissions, rather than just the emissions tied to natural gas operations – including the methane from landfills, cows, and even the leaves rotting in your backyard. Second, these one-time snapshots may get distorted depending on what’s going on while planes fly around capturing methane data.
Historically, top-down approaches estimate emissions that are about twice bottom-up estimates. Some regional top-down methane leak rate estimates have been as high as 8% while some bottom-up estimates have been as low as 1%.
More recent work, including the Science study, have performed coordinated campaigns in which the on-the-ground and aircraft measurements are made concurrently, while carefully modeling emission events.
Helpful gadgets and sound policy
On a sunny morning in October 2013, our research team pulled up to a natural gas gathering compressor station in Texas. Using an $80,000 infrared camera, we immediately located an extraordinarily large leak of colorless, odorless methane that was invisible to the operator, who quickly isolated and fixed the problem.
We then witnessed the methane emissions decline tenfold – the facility leak rate fell from 9.8% to 0.7% before our eyes.
It is not economically feasible, of course, to equip all natural gas workers with $80,000 cameras, or to hire the drivers required to monitor every wellpad on a daily basis when there are 40,000 oil and gas wells in Weld County, Colorado, alone.
But new technologies can make a difference. Our team at Colorado State University is working with the Department of Energy to evaluate gadgetry that will rapidly detect methane emissions. Some of these devices can be deployed today, including inexpensive sensors that can be monitored remotely.
Technology alone won’t solve the problem, however. We believe that slashing the nation’s methane leak rate will require a collaborative effort between industry and government. And based on our experience in Colorado, which has developed some of the nation’s strictest methane emissions regulations, we find that best practices become standard practices with strong regulations.
We believe that the Trump administration’s efforts to roll back regulations, without regard to whether they are working or not, will not only have profound climate impacts. They will also jeopardize the health and safety of all Americans while undercutting efforts by the natural gas industry to cut back on the pollution it produces.
Anthony J. Marchese is Associate Dean for Academic and Student Affairs, Walter Scott Jr. College of Engineering, and Professor, Department of Mechanical Engineering, Colorado State University. Dan Zimmerle is senior research associate and director of METEC, Colorado State University. This post originally appeared at The Conversation.
5 Comments
The equipment required to test valves is not all that
expensive. Today's equipment is ridiculously small (handheld) vs the small suitcase I had to carry around over 20 yrs ago.
Perhaps the authors of the study could perform an analysis on how much money these leaks are costing these businesses?
Let's take a different look at this
The self-described "experts" write: "We believe that the Trump administration’s efforts to roll back regulations, without regard to whether they are working or not, will not only have profound climate impacts. They will also jeopardize the health and safety of all Americans while undercutting efforts by the natural gas industry to cut back on the pollution it produces."
I say, these "experts" want to maintain EPA regulations whether they are working or not, simply to stick a thumb into President Trump's eye because they detest him personally. How removing dubious regulations undercuts efforts by industry to do the right (profitable) thing escapes me.
Got data? @ Wes Stewart
You know this because of a private survey you took at the EPA or something?
I'm sure would be cases where that's true, but it's a bit over the top to ascribe that as a motive to people who have made their careers studying and mitigating risk. To presume it's primarily about personal animus for ONE politician seems unlikely.
I'm sure you could also find people within the EPA who voted for him who also feel that important and effective regulations are now being rendered inert.
So, let's see your data!
Response to Dana Dorsett
"To presume it's primarily about personal animus for ONE politician seems unlikely. "
Since they only mentioned ONE it seems to be to be a fair assessment. They could have easily left out the entire last paragraph without affecting the piece or their credibility one bit. But they simply could not help themselves, so poof, it's gone.
Ah, the consensus of two "experts" @ Wes
There are more experts on methane & regulations than the authors , and "...the Trump administration..." is more than an administration of one. Pruitt & Perry have had a much bigger influence over the regulation rollbacks in question than Trump, but they are (or were) part of that administration.
You may or may not be correct about the authors' personal opinions of Trump, but it would be a mistake to presume that the motive is all about detesting the person at the top. Most researchers working on/for regulatory agency issues believe in the merits of their activity, and take some care to assess the effects (including economic effects) of the proposed or enacted regulations. Regulations don't get made overnight on personal whims & unsupported opinions. These guys measure stuff, and are in a better position than most to understand which of these regulations are working.
