‘Plug-and-Play’ Solar is Closer to Market
A Boston-based research lab has developed a photovoltaic system designed to be installed as easily as a new washer-dryer
Solar in a jiffy. This rooftop photovoltaic system was installed in about an hour. The research and development laboratory developing the system hopes it will dramatically lower the cost of solar installations by 2020.
Image Credit: Susan Young Photography
Although it won’t be commercially available for a couple of years, a photovoltaic system under development by a Boston-based research laboratory could be installed by a homeowner and connected to the grid in about a day.
In a press release, The Fraunhofer Center for Sustainable Energy Systems (CSE) said it had demonstrated the installation of its Plug and Play PV System. Technicians completed the job in an hour. (You can follow the project on Twitter at #FhCSESolar.)
The U.S. Department of Energy’s SunShot Initiative is paying for the research and development project, which CSE said would help bring the cost of solar electricity from $4 per installed watt to $1.50 per watt by 2020, a reduction of more than 60%. The lab said the system “addresses all aspects of the solar purchasing and installation process” by simplifying interconnection, permitting, and inspection.
CSE Director Dr. Christian Hoepfner said in the release the lab is focused on getting technologies such as clean energy into the hands of consumers.
“The Plug and Play system is centered around ease of use and installation to encourage people to adopt solar,” the statement said. “Once commercially available, homeowners will be able to go to their local building supply stores, purchase the PV systems, and install them in less than 10 hours — as easily as installing a washer/dryer combination.”
Making installation as simple as possible
Hoepfner said in a telephone interview the panels use “pretty traditional” crystalline silicone technology. The panels were rated at 175 watts each, small and light enough for someone to carry under an arm, although they also could be produced with a higher rated capacity than that.
They’re attached to the roof with an adhesive made by Royal.
Developers had three major problems to solve, Hoepfner said: making the wiring on the rooftop and down to the side of the house as simple and safe as possible, connecting the panels to the electric meter, and simplifying the interconnection process — that is, hooking it up to the grid.
“We put a lot of thinking into this and in particular a lot of focus on making it safer so that it is basically impossible to accidentally kill yourself on any high voltage on the roof,” he said.
Panels would be connected to the house wiring via a PV socket installed behind the utility’s meter. A licensed electrician or utility worker would have to pull the meter (not something a homeowner could legally do), install a “meter collar” incorporating the socket, and then re-install the meter, a process Hoepfher said should take all of about 10 minutes.
Once the socket was installed, the homeowner shouldn’t need any additional help from a professional. It would be a matter of going to a retail store, buying the panels and installing them.
Once the panels have been commissioned, the system sends data to the local building officials and the utility, “automating the permitting, inspection and interconnection process.”
Solving one of solar’s most pressing problems
If it gets to market, the Plug and Play system would address one of the biggest obstacles to a wider adoption of residential PV — the relatively high “soft” costs of permitting, installation, inspections and other non-hardware components.
In a 2013 report, The Rocky Mountain Institute said hardware costs have dropped sharply since 2008 while progress on bringing down soft costs has been “particularly unimpressive.” That’s one reasons the cost of installed solar electric systems in Germany is half of what it is here.
The report said in part: “Australia and Germany, both with healthy solar markets, have residential solar costs at about half that of the U.S. What’s more, nearly every penny of the savings in upfront capital costs in those countries is due to much lower soft costs. In brief, soft costs have become a national embarrassment.
“Framed more concretely, in the U.S. you could give away solar panels for free and still end up paying nearly $20,000 for a residential system. That may seem absurd, but it’s our current reality.”
Northeast Utilities likes the program
Electric utilities haven’t always been eager to see new residential PV systems. Some have complained that as more homeowners install them and reduce their purchase of electricity, non-solar households have to pick up more of the cost of maintaining the grid. Lower sales of electricity also could lower earnings for shareholders in publicly traded utilities.
That could be a potential rub if homeowners suddenly have an easier, cheaper path toward installing PV. CSE, however, said it has been working with several New England utilities, including Northeast Utilities, National Grid and Green Mountain Power, as it developed the Plug and Play system.
And Northeast responded positively to the demonstration project.
“We at Northeast Utilities see this program as incredibly important because it not only addresses installation barriers, but also simplifies the interconnection process,” Penni Conner, Northeast’s senior vice president and chief customer officer, said in the CSE statement.
“These systems make solar adoption a less complicated and time-consuming process for our customers and easier for us to bring new solar onto our systems. Our customers are going to have easier access to solar, helping us support a more sustainable energy future.”
Why have utilities embraced Plug and Play?
“Most people and most utility executives would agree there are big changes ahead and a lot of uncertainty about that and how it will evolve,” Hoepfner said of distributed solar generation. “On the practical level, however, utilities are required to do this already… Once you do this and the political decision has been made to do this, either voluntarily or involuntarily, then you want to make this as easy as possible.”
Another reason is that Plug and Play would reduce the number of PV systems hooked up without utilities knowing about it. That may not be a huge problem now, Hoepfner said, but as solar becomes cheaper, more people will be tempted to buy panels and install them with or without utility permission.
The CSE Plug and Play, however, can’t be energized unless the utility has actively given its permission to interconnect. That feature would give utilities an “unprecedented level of insight” into how much solar was actually on their grid. Utilities would like that, too.
Don’t go shopping quite yet
Hoepfner said he’s already getting calls from installers who want to know where they can buy the equipment, but it’s two years or more away from store shelves.
In 2015, CSE hopes to move the system from a “technology demonstration” to a “commercially ready prototype,” but it would be 2017 before all of the pieces were in place for retail sales.
It’s not just a single product that needs more complete development, Hoepfner said, but the framework in which a standard is developed, allowing a lot of companies to take part and offer plug and play products. That’s going to take time.
  1. Mikey | | #1
    Not in the Sunshine State
    The Florida Public Service Commission recently approved proposals by the power companies to gut their energy efficiency goals by more than 90% and end the state's solar rebate program at the end of 2015. They're now looking at an FPL proposal to charge ratepayers up to $750M a year for a fracking exploration project in Oklahoma; if FPL gets its way, Duke Energy could follow suit. Duke Energy has already tapped their customers for $1,5B to fund a nuclear plant which was never built.
    Response to Michael Armstrong
    Michael,
    Thanks for your comments. For more information on the topic, see Florida Rolls Back Efficiency Goals.
