Pioneering Near-NZE in Abilene
A regional builder and architect combine solar power, energy efficient construction, and other efficiency features in a four-bedroom home in central Texas
Image 1 of 3
In Big Country. This four-bedroom, three-bath home is expected to perform close to net zero energy.
Image Credit: Sela Builders (images 1 and 2), William Peck & Associates (image 3)
Sela Builders, based in Abilene, says the home’s exterior-wall construction features 2x6 framing and 5 1/2 inches of foam insulation; 7 inches of foam insulation was applied to the roof deck. The NZE home built by Sela Builders was designed by William Peck & Associates, which also has designed more than a dozen energy efficient homes (some at or near NZE) in other towns, including this 2,500-sq.-ft. NZE house in Lewisville, where the architecture firm is based.
Near-net-zero-energy performance in a new home is unusual enough in most communities to attract free publicity. A recent example: a 2,507-sq.-ft. home in southeast Abilene, Texas, that is constructed with superior exterior wall insulation, airtightness, and HVAC, careful solar orientation and well designed roof overhangs, and a 20-panel solar array.
The local newspaper, the Reporter-News, highlighted several features of the recently completed house, which offers four bedrooms, three baths, and a three-car garage, and sits on two acres of land. The main focus of the story, though, was on the building’s green amenities, including exterior walls with 5 1/2 in. of Demilec Agribalance spray foam insulation (yielding R-27 thermal resistance); 7 in. of spray foam in the roof deck (R-33); a reflective, standing-seam metal roof; a conditioned attic with an R-33 deck; a rainwater collection system; and 4 kW of power capacity from the solar installation.
Reckoning with winter cold and summer sun
William Peck, whose architecture firm designed the house – and more than a dozen near-NZE homes in other parts of the state – said it is equipped with Pella double-glazed vinyl windows with a .29 solar heat gain coefficient. He also noted, though, that all of the critical windows are shaded.
And because winters in central Texas can include freezing temperatures and snow as well as mild days, the house features a high-efficiency pellet stove (capable of heating 1,500 sq. ft. of the house), and, to manage the summer heat, a 16 SEER HVAC system with timed exhaust, and variable-speed air handlers.
Constructed by Abilene-based Sela Builders for about $120 a square foot (versus traditional-construction costs of about $88), the house also features two air-source heat pumps for hot water. The local power company, Taylor Power Cooperative, will be monitoring the home’s energy performance, the company’s director of business development, James McKee, told the Reporter-News. “We’re seeing this house as a bit of a test tube baby for us,” he said. “We’ll be watching very closely and gathering data for future projects.”
At this point, Peck noted, the house, which is listed for $375,000, is considered “net-zero-energy-capable,” but could easily achieve NZE performance should its eventual owners decide to slightly expand the solar installation. A year of monitoring by Taylor Power should provide enough data to determine how much, if any, system expansion might be needed to reach zero.
