![](http://images.greenbuildingadvisor.com/app/uploads/2021/04/26144322/Owens-Corning-screen-shot-4-700x421.jpg)
A recent GBA comment posted by someone named Joel included a link to an instructional video produced by Owens Corning, a manufacturer of extruded polystyrene (XPS) rigid foam insulation. Joel noticed that the Owens Corning advice was at odds with advice provided on the GBA site, and he asked editors at GBA to clarify the discrepancies.
First posted to YouTube on May 23, 2018, the Owens Corning video (apparently titled “Foamular Attic Ceiling Insulation”) offers startlingly bad advice. Not only is the advice incomplete, but the video recommends two dangerous insulation techniques: one that is associated with damp roof sheathing, and another that violates building codes.
The video was an official Owens Corning video, and it was posted on several web sites in addition to YouTube, including on the Owens Corning web site where it was listed in the company’s library of instructional videos. The publication of this video by a major U.S. manufacturer highlights the current crisis in residential building quality, and the role that materials manufacturers play in perpetuating discredited construction methods.
The advice is incomplete, risky, and illegal
The Owens Corning video explains three ways that homeowners or builders can use to insulate sloped ceilings.
Method #1 is a vented roof assembly using XPS to make site-built ventilation baffles. According to the voiceover on the video, once the ventilation baffles have been installed, the rest of the rafter bay can be filled with fiberglass batts. (For now, we’ll ignore the fact that the video shows a remarkably sloppy method of batt installation—one that leaves voids between the batts and the drywall.)
This suggested method might work, but only if the R-value of the total assembly meets code minimum R-value requirements. The video ignores code requirements for R-value.
Method #2 suggests the creation of an unvented roof…
5 Comments
I took a look at some of the Owens Corning asphalt roof shingle warranties (https://www.owenscorning.com/en-us/roofing/warranty/) and found an irony. For example, their "System Protection" warranty contains this language: "Your Roofing System must cover the entire structure, be installed over a ventilated roof deck, and include a code approved underlayment. Incomplete roofs installed on a portion of a building do not qualify nor do roofs installed over non-ventilated decks."
Maybe the reason they are hesitant to offer their extended warranties on unventilated roof decks is that their own company has been teaching people how to set them up for disaster!
Patrick,
I guess the apparent contradiction can be explained if we assume that the unvented roof assemblies that Owens Corning proposes in their video must be topped with roofing from a different manufacturer -- Owens Corning shingles won't work.
Just get it done. Get that house finished! I've got buyers lined up and want to close the sale this week.
There is building science and building marketing.... apply the the Dilbert principles that marketing always trumps science and engineering,
I did consider the "hot roof" approach briefly for our cape-cod but decided against it when accepting that I don't have the knowledge/skill to install spray foam nor the money. Instead, I went with plastic baffles from the eaves to the attic. I'm glad I didn't see this OC video when researching how to insulate.
But it's a good reminder to be aware of advertising and that the not all experts are created equal.
