![](http://images.greenbuildingadvisor.com/app/uploads/2018/07/24223311/Montague%20house%20-%20exterior-main.jpg)
Energy experts often repeat the cliché, “There’s no such thing as a zero-energy home — just zero-energy homeowners.” Energy monitoring data from two well-publicized Massachusetts homes — the so-called Montague Urban Homestead house in Turners Falls and the home of Matt and Laura Beaton in Shrewsbury — prove the cliché to be true.
Energy-use data for the two homes were shared in a presentation by Mike Duclos and Paul Panish at the Better Buildings by Design conference in Burlington, Vermont, on February 8, 2012. Duclos and Panish are energy consultants at the DEAP Energy Group in Newton, Mass.
The first of the two houses, the Montague house, is owned by Tina Clarke and Doug Stephens. It has won at least two awards: the $25,000 Massachusetts Zero Energy Challenge, and NESEA’s $10,000 Zero Energy prize. Energy-use data from the Montague house show that the homeowners used far less energy than predicted by energy models.
The other house discussed by Duclos and Panish, Matt Beaton’s house in Shrewsbury, is the first certified Passivhaus in Massachusetts. Energy use data from the Beaton house show that the homeowners used far more energy than predicted.
The key factor in both cases was occupant behavior.
The Montague house
The Montague house was built by Bick Corsa with help from the homeowners. Construction was completed in 2009.
Here’s a snapshot of the house:
56 Comments
Wow
Continuous 1kW load in a Passivhaus? The mind boggles. :) Having chosen a passivhaus, I guess I would have expected occupants to be more savvy about energy. LED TV vs. Plasma, for starters? And I'm a little surprised that the entertainment center wasn't on a switched outlet or something?
I'm starting to think more and more that the always on / continuous load is one of the very first things to look at in an energy audit, speaking as an outsider to all this. :)
Ah, the human factor.
No engineering that away.
Renewable Electricity
It sounds like the Beatons would be good candidates for a PV system.
effect of monitoring
In the discussions here on the use of monitoring to measure building performance, I've wondered if "knowing" would impact behavior .... if seeing the effect of my behavior on load and cumulative use ... and cost ... would be a nagging reminder to change what I do.
Is there any plan to go back to these folks' houses later on ... to see if the Beatons adjust in some meaningful way ... or if the residents of the Montague house tire of their disciplined usage and find a different comfort range. Did Duclos or Parish mention follow up, Martin?
I dunno
Their 'bad' behavior still uses a lot less total energy than many of us [hand raised]
similar range
We've seen similar ranges in our small sample of new houses. Obviously good design and careful construction is important, but strong buy-in by occupants is critical. Yes, they're going to use less power living large in a Passive House than in an Energy Star house, but if their energy consumption gets publicized as the norm for high performance homes, it is hardly good advertising for the importance of the work.
Response to Keith
Good point. Of course this does point out that homeowner behavior constitutes a major variable to cost/benefit projections. A dramatic rise in future energy costs (an even bigger variable) would perhaps get the homeowners attention and improve their energy habits. So it all might even out. And at the very least they now have better options than most of us.
that means beaton house
that means beaton house missed the mark on performing as a passivhaus. the worst case they could have done energy-wise was 14,015kWh/a. for me, this further cements the notion that we should be striving to adopt the energy consumption of the germans or swiss, instead of trying to adopt PHPP/passive house to the average american's horrible consumption.
sooooo
If one buys a Nissan Leaf one loses ones certification?
You can lead a horse to water..............
Initial construction costs also have weight.
How much did the Beaton's house cost? I wouldn't be surprised if it cashed in around $350/ft--a huge investment for, in my opinion, not much more than status and conversation. I can't see the payback being worth it... Given that the Montague house is basically a double 2x4 home with great attention to insulation detail, ornamented with renewable energy and fiberglass windows, the $174/foot is still a high cost (not by much, but still high) in my opinion. Kudos to the Montagues for conservative energy use practices, but I think that getting a home in the $125/ft range is do-able. At about $50/ft more than traditional energy star home building, I can see payback, but not for a while... I'm building a 3400 sq ft --a pretty good house (attention to insulation, but not dedicated to it-....R-10 below basement slab, R-30 walls, R 45 roof in southern NJ)--home using icf, concrete, steel, for just under $50/ft...Granted, I'm doing 85% solo, but still doing it....Careful shopping, doing the research & design yourself, and flexible plans are a big part of the secret.
I think it's more important to compare the performance of the house to its cost per ft because that's pretty much the bottom line. Energy consumption can always be offset by energy production, but the cost of energy efficiency must be able to realistically be pay for itself in savings within a reasonable amount of time (in my opinion, no more than 7 yrs).
Payback
Why 7 years? If you've got a 30 year mortgage, and financing the cost of energy upgrades is less than the savings from those upgrades, isn't that a good deal? Saving you $ from day 1?
Response to Joe W
Joe,
Studies of the effects of real-time energy use monitors with displays in the kitchen or living room have generally shown that the installation of such monitors results in energy savings, but the degree of the savings and the longevity of the effect are in some dispute. Read more here: Home Dashboards Help Reduce Energy Use.
Q. "Is there any plan to go back to these folks' houses later on, to see if the Beatons adjust in some meaningful way, or if the residents of the Montague house tire of their disciplined usage and find a different comfort range?"
A. I'm not sure; I can check with the researchers. But I think focusing on these two families misses the point. We could all write different endings to this particular drama: the Montague residents could either become extreme Luddites, and set their thermostats at 42°F -- or perhaps they could discover a new, energy-intensive hobby, like art welding. Perhaps Matt Beaton will fall off his donkey on the road to Damascus, and resolve to cut his energy use in half -- or perhaps he could install a huge conditioned wine cellar in this basement.
What I'm saying is, the personal dramas of these families is not the point. The point is that this bell-curve phenomenon exists, and the range is very large. I think we should keep that point in mind when determining whether Passivhaus obsessiveness -- Is it 0.6 ach50 or 0.7 ach50? -- makes any sense.
re Martin
No, certainly the point reaches a million miles beyond the two families. I was hoping that someone was measuring and monitoring and was seeing that some people -- some being the important word -- were able to learn from their needless overindulgences.
Such growth doesn't seem to me to be particularly technical but it does seem to fit the behavior of an adult.
Back to the regularly scheduled programing.
Response to Martin Holladay
Martin:
"What I'm saying is, the personal dramas of these families is not the point." Thanks - Well said.
"I think we should keep that point in mind when determining whether Passivhaus obsessiveness -- Is it 0.6 ach50 or 0.7 ach50? -- makes any sense."
We (green building industry) are good at envelopes but aren't really effective at changing occupant behavior. Just because part of the problem is beyond our scope of effective influence, let's not loose the energy in "normalizing" major strides in envelope design and practices.
It's American "obsessiveness" that get's an awful lot done in this world. I don't think it's time to "relax" our obsessiveness, curiosity, or expectation that "getting good" at "getting tight" is a realistic or worthwhile goal.
As businesses we do have to "fit the market", so "pretty good" is as important as "Passivhaus". But lets not pretend that "obsession" and the "pressure to improve" are not necessary and valuable.
Response to Albert Rooks
Albert,
You wrote, "I don't think it's time to relax our obsessiveness, curiosity, or expectation that getting good at getting tight is a realistic or worthwhile goal."
I'm all in favor of air tightness and thick insulation, but I'm skeptical of the value of PHPP modeling, an exercise that requires many hours of expensive labor.
At the recent NESEA conference in Boston, Alan Gibson of GO Logic in Maine presented monitoring data on the so-called GO Home Passivhaus. During the period from November 2010 to November 2011, here's how the 6,947 kWh broke down: Lights and plug loads, 64%; ERV, 14%; Space heating, 12%; kitchen appliances, 12%. (During this time frame, there was no domestic hot water use because the house was used as an office.)
During a subsequent four-month period of monitoring, after a family had moved in, the percentages were a little different: Lights and plug loads, 28%; Kitchen appliances, 24%; Domestic hot water, 23%; ERV, 15%; Space heating, 11%.
Albert, as you can see, it's great to build a tight envelope and install lots of insulation. But we don't need to spend days filling out PHPP spreadsheets, because space heating isn't a problem.
It's all about the plug loads, which means it's all about occupant behavior.
Plug Loads, Plug Loads
Yep, plug loads are undoubtedly a huge driver in building energy use today and will be moving forward. When I look at the Beaton House or the GO Logic Home though, I see a building that's ready for the future. Not just for short-term bragging rights (with award money!) of having the most efficient residents' behavior. We are continuing to detail our buildings for the near future yet hoping to utilize them for 50+ years.
If inefficient appliances, devices, plasma TVs, 15mpg SUVs and the like aren't confined to the obsolete heap in the closer future, in my mind all this work will be a sideshow. So, I'm working on the premise that in a generation or two, society will have at it's disposal much lower-energy using fixtures. The infrastructure we are constructing though will be there for the long-haul and needs to be crafted with the best design we can when we create it.
Sure it takes a few hours to run a building through the PHPP (or a thorough modeling program), but I can tell you clearly that it allows informed choices regarding where to put the additional effort during construction. Where can we best spend the additional $ on these structures? (Insulation in the roof, wall, sub-slab, foundation; windows - solar heat gain, U-values of frames, glazing, sizing, orientation (doors too); ventilation system efficiencies; building orientation; envelope shape; the mechanical systems...) The list is VERY long yet it can be optimized, for initial installation cost as well as long-term usage. Only relying on prescriptive measures doesn't account for the intricacies of building for optimal performance. That said, I don't see every individual project going through extensive modeling, though many, especially unique ones and larger ones, will benefit. As the tools become easier and more widely used, however, I personally hope that in that next generation it will be standard practice.
So, with the hope that nearly all structures built or significantly retrofitted are looking for the 50-100+ year return, I think it's another tragic case of American short-sightedness that we stop short of where they could be for fear of engaging a relatively small effort.
Response to Dan Whitmore
Dan,
Many builders have known for years what a "pretty good house" looks like in their climate zone. Here in Vermont, smart builders have (for many years) been building rectangular 2-story buildings without bump-outs, with the long orientation east-west, and built with attention to air sealing, with the following insulation levels: R-15 or R-20 basement walls, R-30 or R-40 above-grade walls, and R-60 attic floors. We've been installing orientation-specific triple glazing, with about half of the glass area on the south side, and very little or no glazing on the north.
Many builders have been building this way for 20 years -- without PHPP. And you know what? The difference between this house and a house with a $3,000 Passive House consultant is less than one plasma TV. Furthermore, the difference can be in either direction -- because many wealthy homeowners who can afford to hire a Passive House consultant use more gadgets than the frugal Vermonters who make do without consultants.
I'm convinced that experienced builders and designers can learn the difference between an energy-hog building and a well-designed building without thermal bridges or nosebleeds -- and that a good builder or designer can develop a gut reaction to design suggestions.
For example, when I first saw Katrin Klingenberg's Smith house, my first reaction -- one I think would be shared by any builder who designed passive solar homes in the 1970s and early 1980s -- was, "this house is going to overheat in March and October." Although the house went through the PHPP process, it apparently didn't go through the process of vetting by an experienced builder.
Klingenberg later had to install a trellis to keep the sun out of her house during the swing seasons and the summer.
I think that it would be great if architects had to play around with PHPP in architecture school. (Hopefully they'll use a version of PHPP that does a better job of predicting overheating.) Then, if we're lucky, architects might graduate with a well-developed sense of what a good building looks like.
As an experienced builder, I
As an experienced builder, I find it very rewarding to be able to use modern modeling tools to test my 'gut reactions' before the nails fly. Some were right some were wrong. But now I don't need to depend on notoriously subjective occupant behavior/feedback, as your article demonstrates very well, to determine how what has already been built may perform.
Certainly for reputable, forward thinking builders a $3000 additional fee may not be necessary (though for a standard SF house that seems to be a number out of an over-sized hat - including all rating and certification, maybe?) However, watching 3 new places go up right nearby me and seeing them receive Built Green 4 Star Ratings (4 out of 5 possible, which didn't come free, I assure you) while putting together a basically energy-code building makes me very disappointed. Now the developer is selling them for about $550K in the low-rent part of Seattle? Seems like it would have been money very well spent convincing reticent individuals on what is a good path/goal to work with.
Re the trellis on the Smith House, my recollection is that was planned from the beginning, installation just waited until feasible.
My first passive solar SIPs
My first passive solar SIPs house sold to a couple that bought it because of the view, floor plan and schools. They drove a SUV and had jet skis and snowmobiles, no bikes or skis. The monitored results were very disappointing!
What we can do is well thought out electrical switching and lighting so at least the occupant has the option to manage use.
Often thought meters or monitors that had readouts in flashing $Amounts$, might help.
Or maybe an electric meter that you had to feed with quarters and you could only buy 20 kWh at a time.
At some point in the life of the buildings we are building today, energy costs will be high enough that IT WILL MATTER!!!
Dan,
You wrote, "As an experienced builder, I find it very rewarding to be able to use modern modeling tools to test my 'gut reactions' before the nails fly. Some were right some were wrong."
I don't doubt what you are saying. I'm saying something else: that the BTU difference between the two alternatives that might fool an experienced builder like you are so small that they fall into the category I call "misplaced accuracy."
You are worried about the PHPP subtleties -- by definition, subtleties that are so small that your gut is wrong -- and then the occupants move in with all their stuff from WalMart, and plug everything in. Space heating is 15% of energy use, and plug loads might be 55%. So why were you sweating over PHPP?
You wrote, "I don't need to depend on notoriously subjective occupant behavior/feedback." I don't depend on feedback monitors either, because the occupants will do what the occupants will do. These monitors might help a little, and they can't hurt, but the real motivator is the price of energy. That's why we need to lobby our legislators for carbon taxes.
Response to Richard Patterman
Richard,
Good points.
You wrote, "I often thought that meters or monitors that had readouts in flashing $Amounts$, might help. Or maybe an electric meter that you had to feed with quarters and you could only buy 20 kWh at a time."
Both gadgets exist. If you want an energy-use monitor with an indoor display calibrated in dollars, you can choose The Energy Detective monitor or the PowerCost monitor.
Prepaid electrical meters are manufactured by several South African companies. They are usually installed in low-income neighborhoods; residents can't use electricity until the electronic meter is loaded with a payment. (These meters generally don't accept coins, however; they usually require some type of electronic funds transfer.) When you use up all of the electricity that you have already paid for, your house goes dark.
As you can imagine, these meters have colonial overtones, and are often viewed unfavorably in low-income neighborhoods.
For more information on prepaid electric meters, see:
Battle brewing over prepaid electric meters
A distributor of prepaid electric meters
Prepaid electric meters in India
Oklahoma utilities are eager to test prepaid electric meters
Richard, Martin,loving the
Richard, Martin,loving the banter, points,info and all in the last few posts.
Response to Martin Holladay re: value of modeling
Martin,
You're certainly not going to let any "program" off with a "pass". Good. We are all forced to do our work better when we have to prove project performance, value and our own biases.
If I'm following you correctly it seems that you are questioning the value of taking the extra step of modeling the project with the PHPP because these cases illustrate that it could be a wasted effort due to:
Marginal performance gains vs cost of modeling.
Potential fall/spring over heating due to using solar gain to meet demand criteria
Moderate gains wiped out: "the occupants move in with all their stuff from WalMart, and plug everything in. Space heating is 15% of energy use, and plug loads might be 55%."
I agree with your skepticism.
Sometimes it would not make sense to model a project in PHPP: Simple straight forward projects where the clients are not interested in approaching or meeting the Passive House standard do not make sense. However, it seems to me that when the site is less optimal with poor solar access or other issues, then modeling with the PHPP can bring a level of accuracy that is extremely useful... If one chooses to use it, and regardless of a desire for PH certification.
The potential overheating question seems to nag at you... It's kept coming back to me over the last year too. Sure, increasing glazing to meet the heating demand is a tool that helps the designer meet the demand criteria. Sure it can be misjudged, or in fact mis-used. I don't think that you can blame the PHPP for overheating anymore that you can blame a saw for lost fingers. Its depends on who's hands the tool is in. And even when it's in good hands, mistakes happen. -Ouy! I'd certainly lean towards a little F/S overheating right now... In the Pacific Northwest it's been endless grey rainy days. I'd like more glazing, more light. The "seasonal affective disorder" has set it and it sucks.. At least too much glazing can be fixed with a little shading...
As to the Occupants: Well that is a least the one bright spot. They can change their behavior. That's the one thing in this whole scenario that can change (other than shading). Once the building envelop is done, it's done. Let's not relax skills or expense just because occupant behavior is out of our control.
Keeping everything in perspective
Albert,
I agree with most of your points. Most homes don't need PHPP modeling, but the occasional modeling exercise is useful to keep a designer on his or her toes.
As we chase those last decimal points and save those last few BTUs -- at a price per BTU that rises steeply the deeper we dig -- we need to keep everything in perspective. To me, the fact that domestic hot water use and plug loads dominate usage mean that we need to focus on those items. Our nitpicking about small envelope details is a historical legacy from the 1970s; it's time to move on.
Reply to Martin
"I'm convinced that experienced builders and designers can learn the difference between an energy-hog building and a well-designed building without thermal bridges or nosebleeds -- and that a good builder or designer can develop a gut reaction to design suggestions."
Martin, I couldn't agree with you more! In theory, builders probably don't need to get very expensive passive house designation when they seal a building properly. However, what I've found is that there are many builders out there who build on spec. and don't really care how tight a building envelope is but are more concerned about their profit margins. A certification, whether LEED Gold or Platinum or Passivehaus, lets a prospective buyer know the building has been built to high energy efficient standards because it has passed certain minimum requirements as determined by an independent third party.
As many excellent and reputable builders as there are out there, there are unfortunately just as many who've gotten into the business to make a fast buck, and since a consumer buys a house only a few times in his or her lifetime, they're not going to necessarily be able to ferret out the good builders from the not so good. A certification gives them the confidence to know they're buying a well-made house.
I know this is off-topic, but I thought I'd chime in. Re occupant behaviour, as mentioned, the simplest way to get people to conserve is through price hikes. Simple, but effective -- just ask the Europeans.
Cost of House #2
Can somebody knowledgeable throw us bone as to the cost of House #2? A rough number perhaps? It completely takes away from the relativity of the comparison, at least on one level which I truly desire to know!
occupant behavior
If occupant behavior is unpredictable, that's all the more reason to build the best envelope and HVAC system possible. It isn't my role to judge the future occupants of the buildings I design. In many cases I don't know who they will be.
Why sweat space heating if it's only 15% of the total energy use? Because that's what I can control as an architect. I can't tell the future residents that they aren't allowed to have a DVR or a home office.
Controlling what we can
It may be true that “There’s no such thing as a zero-energy home — just zero-energy homeowners" but in all but the mildest climates you cannot be a zero-energy homeowner without a very well performing home. That will only be more true going forward. As designers and builders of quality structures we want our buildings to outlive the average, hopefully but a factor of two. So we are obligated to build to the highest standards available today. And while we'd all love to educate all of the future occupants of our buildings in the ways of low impact living, realistically we can only influence a few of them. So we control what we can control and give currant and future occupants the tools they need.
It's great to hear that most builders in Vermont can build to near Passive House levels without modeling, or probably even plans for that matter, but if you look around this country you will not find this the norm. Code minimum with no site specific features. Certifications like Passive House offer buyers confidence, builders an opportunity to differentiate their product, and regulators and utilities valuable planning tools. If PHPP under-reports average plug load usage, or is unduly cumbersome or time consuming, that's a problem with the modeler, not a reason not to perform energy (or daylight, or ventilation) modeling.
educating occupants is part of our job
In recent years, my work (which is 100% new construction) has shifted from builders to homeowners. This has allowed me to attack occupant behavior. I spend a significant amount of time talking to clients about dhw and plug loads. Each person and family is obviously different, but in all cases it's important for the homeowner to have a sense of the relative impact of envelope loads compared to DHW and appliance/plug loads. In particular, those who do care about modifying their behavior need to have a better sense of where their efforts will pay off the most.
I encourage clients to purchase a couple of Kill-A-Watt modules. Some folks are more curious than others, but those who embrace this type of energy sleuthing typically find it to be "eye-opening" and are more successful in reducing overall energy consumption.
As Martin points out in his follow-up replies, when you consider the already low cost of heating and cooling a home that gets all the basics right, it doesn't make a lot of sense to pile R125 insulation in the attic or seal the house to sub-1.0 ACH50.
Regarding the Beaton windows... the relatively high-gain windows (shgc 0.55) on the non-south windows jumped out at me. Not surprising that cooling loads are higher than predicted, and it's not just the internal loads that are the culprit. This could easily have been avoided. What would really be interesting (for the Beaton house) is how much of their annual energy load is attributed to heating and cooling.
In my experience, and in my opinion, PH doesn't do a great job of addressing cooling loads (see my comments here).
David Butler
optimalbuilding.com
Response to Geoff Briggs
Geoff,
You wrote, "It's great to hear that most builders in Vermont can build to near Passive House levels without modeling."
Not most builders, alas -- but a small subset of builders who pay attention to energy efficiency and superinsulation.
Occupants need a new level of choices
What irks me most is the wasted energy.
Changing behavior for an occupant is probably challenging. It's one thing to argue with a teenager about leaving lights on and taking shorter showers. I can understand that people get attached to their comforts and are resistant to change.
However, the stuff that really frustrates me are the phantom loads. I've got the usual array off electron sucking gadgets: and no real way to control the loads unless I unplug them. Sometimes I do and sometimes I forget. And I actually care about the issue. I could just imagine getting the "blank stare" from those who really don't understand the level of consumption going on and don't care enough to make it a priority.
Does it make sense to try a new approach? Why not run the wall circuits like we do our heat?
Put all room outlet circuits through a programable module just like a programable thermostat:
Just like programing a thermostat to turn the heat down while your a sleep or away, it could turn off the wall circuits during the same periods: Off goes the cable box, Plasma TV, phone,computer/printer transformers... Program out the periods where no one gets any comfort or benefit out of these loads.
I used to think that we should be adding "kill switches" to each room, but now I've moved on to looking at the whole system. It's not really that complicated to imagine a scenario where there is a line voltage relay system at the panel location that is controlling each (most?) room outlet circuits. The whole system can be programed by the occupants. A further backup could be in each room that is a simple override that when pushed will enable the rooms circuits (for like when you get up in the middle of the night). The room overrides could be done cheaply by low voltage rather than line voltage since they are controlling a relay system.
The point is that so far all of the suggestions require occupants to think, make decisions, and act. Something they probably don't want to do. If we can automate the shutdown of phantom loads like we rollback temps, it would probably work.
Has anyone had experience with curbing phantom loads other than just adding switched plug strips? Could this be a realistic solution? There's gotta be more solutions that can be developed.
Response to Jason Burk
Jason,
Q. "Can somebody knowledgeable throw us bone as to the cost of House #2? A rough number perhaps?"
A. As far as I can tell, the construction cost of this house has not been made public. But it's safe to estimate that it cost more than $100 a square foot, and probably cost less than $200 a square foot. That would put the construction cost somewhere in the range of $340,000 to $680,000.
Response to Greg Duncan
Greg,
Q. "Why sweat space heating if it's only 15% of the total energy use? Because that's what I can control as an architect."
A. Fair enough. But if you are facing a tough decision at the design stage and need to determine whether an expensive envelope measure is worth it -- a change that might save 7% of the heating cost -- it's important to remember that this represents only 1% of the energy use of the home.
Albert,
As someone who has lived off-grid for 30 years, I think there are two basic approaches to the problem of electronic devices with high phantom loads:
1. Buy as few of these devices as possible.
2. Put them on plug strips.
Really, it's not that hard. Of course, I don't have an automatic garage door opener, a digital video recorder, or a doorbell with a 24-hour transformer. But it sure saves the batteries from getting run down in the winter.
It would take 10 cents worth
It would take 10 cents worth of hardware to turn every wall wart from a .5 watt standby draw to a 0 watt. It is 10 more cents than they want to spend. Similarly tvs etc could change from constantly drawing to charging a battery and monitoring it
On positive thing I have seen is the proliferation of usb chargers, meaning you can migrate toward one power strip if you choose
vampire loads
@Albert, the scheme you described, using programmable relays, would cost far more than the energy saved in a lifetime. Actually, this type of system has been around for decades (based on GE RR-7 relay modules), and was at one time used by "home automation" pioneers. But unless a house is wired specifically with this in mind, killing an entire circuit to control plug loads would also disable lights. Not to mention having to reset all the clocks in electronic devices, as very few have b/u batteries.
As Keith pointed out, it costs very little to build devices with low standby power requirements. In fact, there's actually been a *lot* of activity in recent years aimed at reducing standby power in electronic devices (DoE and industry groups, see this). Great progress has been made, especially with TV's and set-top boxes, among the worst offenders. For example, my 8-yr-old satellite DVR consumes 50W whether it's on or off, but according to this table, the average is less than half of that with current models.
Computers are easy. Virtually all desktop computers sold in the last decade have standby or sleep mode (assuming user uses this feature). And laptops have had excellent power management since the beginning.
The key is to identify which devices are the biggest culprits in your home and focus on those, rather than trying to control everything. And there's plenty of information on the Internet to help folks make wise purchase decisions. Awareness & education are the key.
Get rid of the "zero"
The article starts: "Energy experts often repeat the cliché, “There’s no such thing as a zero-energy home — just zero-energy homeowners.”"
Actually there is no such thing as either.
It's too bad someone coined such an incorrect term as "zero-energy home". A lot of energy went into the materials and construction of the home. Energy is expended daily in every home regardless how efficient it is and even if it produces its own energy by solar, wind or water. Energy comes into the home from the sun and the people that live in the home.
Likewise there are no "zero-energy homeowners". Every person uses energy.
Even the term "net-zero-energy home" is neither accurate nor a clear term to the average person not deeply immersed in green buildings and living.
Can't someone come up with an accurate and easily understandable term? Get rid of the "zero" because that is definitely out of place. My first thought is "energy-self-reliant home".
Also, most seem perfectly satisfied if a home merely produces as much energy every year as it consumes each year and totally ignore the embodied energy and materials. If someone wants to boast, shouldn't they also strive to produce the embodied energy in their home too? Perhaps we could give them 50 years.
Payback
Dan Kolbert
Why 7 years? If you've got a 30 year mortgage, and financing the cost of energy upgrades is less than the savings from those upgrades, isn't that a good deal? Saving you $ from day 1?"
Payback and saving (meaning spending less) money are nice things when it happens. However, I think the green movement shot itself in the foot by talking about payback so much. There is no payback for many things that we should do to protect the environment and our health. Because the idea of payback has become so imbedded in so many people's minds, they refuse to consider green things that "aren't worth it" financially. The irony is, that virtually all of our consumption has absolutely no payback and no one balks about buying a TV, or fancy car or any of the many other things we buy. They are not investments, they are expenditures for consumables - things that eventually wear out and their materials and embodied energy are consumed.
We need to promote an attitude that finds it desirable to spend money for things that are truly good for the health of the Earth and the people, animals and plants that live on it. I lived in Germany for 29 years and personally experienced the media promoting a green attitude and the populace in general accepting that new way of thinking. Wednesday afternoons and Saturday mornings the village recycling center had a line of cars bringing things there to be recycled. When I left the country in 2002 all of the trash receptacles in the Frankfurt airport consisted of three containers: one for paper, one for recyclables and one for garbage. And the people knew what belonged where and discarded their things in the correct containers.
Passivhaus is not the only green concept that we can learn from the Germans. Our village of 3,000 started requiring rain-water harvesting for all new homes. Wind and solar energy were promoted by the government so that Germany was the world leader in installed systems until recently. Every recyclable product has a small fee as part of the price to cover the cost of recycling and an emblem to signify that. The railroads are promoted as a much more efficient method of transportation than long-distance trucking. In general, the populace is intelligent and understands and accepts the logic of the various attitudes and behaviors. What has been accomplished in Germany could also be accomplished in the United States. We have started in the right direction but there needs to be a greater public emphasis on green thinking and living.
Monitor before building
As this article makes clear, modeling a building's design is not sufficient to ensure low energy use.
Perhaps people’s lives should be monitored before designing and building a house for them. If they have had a big TV going six hours a day until now, that isn’t going to change in a new home.
Phantom loads
albert rooks:
"Has anyone had experience with curbing phantom loads other than just adding switched plug strips? Could this be a realistic solution? There's gotta be more solutions that can be developed."
I've used switched plug strips to shut off all the electronics at my desk but they are probably often hidden behind the desk to keep all the power supplies and cables out of the way and out of sight. Inconvenience means that they stay on all the time. If you knew ahead of time where those things would be located you could connect one outlet to a switch by the room's light switch. But what if you charge your phone by the computer during the night? Disconnecting that outlet would not only disconnect all the computer hardware but also the phone charger. When I lived in Germany I made my own power strip with about eight outlets and each had a separate labeled switch.
I bought a Kill A Watt at Home Depot and have had my HTC Evo 3D phone charger plugged in for 41 hours. I usually leave my phone on the charger when I'm at home so that it's always fully charged. Looking at the Kill A Watt display I noticed that it draws 2.5 - 5 watts when the display is on. 1.5 watts when the display is off. 0 watts when the phone is unplugged from the charger but the charger is still connected to the Kill A Watt. So, this HTC charger has no phantom load. Total cost for the year it has calculated at $0.86. A charger for another device that is fully charged is drawing 0 watts. So some manufacturers are designing chargers with no phantom load when not actually charging. My laptop is using 30-35 watts while using it.
It was also mentioned: "It's one thing to argue with a teenager about leaving lights on and taking shorter showers."
I would suggest some understanding of teenagers' developing sexuality in this context. This could be their only place of total privacy to experience this part of their being. Unless you prefer them to find a girlfriend or boyfriend. But that could be far more costly. By the way, my 58-year-old partner very much enjoys the pulsating shower head I gave her two years ago. I would suggest that you add a bit more hot water to your list of essentials for a happy life and stop complaining to the kids.
Response to Neil Porter
Neil,
Thanks for the smile -- and the reminder that there is more to life than energy conservation.
Stat Down???????
Any idiot can turn-down the stat to 60 and off when not at home, and save energy. Did they buy hoodies and Carhartts with the savings. I spent 2 days with no power last week because of a power line failure and it was not fun-- had to turn on the gas stove a couple of times to heat up a bit. I, like other people need 68-70 F. to stay comfortable and 66 F. while in bed. I hope Carhartts are not the new sleepwear fashion.
Gene Batema,
Licensed Michigan GC.
Response to Gene Batema
Gene,
As noted in the article, “These are not normal users.” Their habits were described, not advocated.
Response to David: Kill the Vampires.
David,
Thanks for the reply,
I think the problem is bigger, and getting bigger as we go:
Yes the trend is forcing industry to make devices with lower standy loads. But the number of household devices with a standby mode (and load) are increasing.
For you and I, some of the loads can be controlled by power strips, but for most of the country, it's not a practical solution. Most of the US is not aware or care enough about the issue to act on it. Even if they were, they don't have a practical way of controlling the loads. The average house has too many devices that are too spread out. Add children into the mix of daily life and I'm sure it becomes more challenging.
I wish I could believe that most of the US would make it part of their daily routine to turn off the loads that are not needed to be in standby when the household is asleep or away. There are really too many to control individually: Garage door systems, Internet modem, wireless router(s), entertainment centers with cable/sat box, TV, Stereo, wireless network printers, Kids laptops, Gameboxes.... The list seems to get longer every year. All of them constantly drawing.
That list represents all of the electronic stuff that is on it's way out of big box retailers and into an American home seven days a week. I don't know, but I don't think that the buyers are concerned about the in-use plug loads, let alone the standby loads.
Yes, I'm reaching back to the "home automation days" in thinking of introducing new control measures for the circuits that supply these things. These days it would be far easier in new construction: Lighting and plug load circuits are already separated, We don't have to use the old magnetic relays, surely there are now ways of managing multiple line voltage circuits without significant loads.
The question came up because of the contrast in the two households here, and that this week I'm working with our regional Passive House Association (Passive House Northwest) writing proposals for consideration in this round of Washington State Energy Code cycle. For the code cycle all we are trying to do at this point is defend and support the ICC 2012 improvements. It just got me to thinking about all of those constant loads that are wasted in an empty or sleeping households.
Perhaps it's time to return to some of those original "home automation" idea's. I think plug load circuit automation integrated into the developing new home "systems" has something to offer.
Response to Neil: Those darn kids.
"I would suggest that you add a bit more hot water to your list of essentials for a happy life and stop complaining to the kids."
Neil,
We raised 4 kids through the teen years and all are grown up and on their way in life. My statement was based on my experience on the difficulty of talking about resource conservation to a teenager. Some take to it easily while others understand it, but have a difficult time maintaing awareness of it. I agree that it's a balance, but I do see talking about consumption and limits as an important part of parenting.
Albert, I think you are
Albert, I think you are looking for phantom solutions to absurdity.
I have lots of phantom loads and their total power is minuscule compared to any other load.
Lastly, industry is rapidly solving all this with well designed newer products every day that goes by. Moors law is working wonderfully.
Ultimately the culture is more important than the science
In "Is Efficiency Sufficient?" (prepared for the European Council for an Energy Efficient Economy (eceee) with funding from the European Climate Foundation and the U.S. Environmental Protection Agency’s ENERGY STAR Program), Chis Calwell notes that we've successfully increased efficiency, but energy loads are increasing. We could start a Manhattan project for efficiency, but unless we have a serious cultural shift in our approach not only to energy but to material, we will continue our trend to increased energy consumption.
The elephant in the living room is, well, the living room! When I was growing up we had a huge black & white TV in the living room. The lights dimmed when it came on, it took two and a half minutes to warm up and baked the paint off the shelf above it. But we turned it on a half hour a day (well, an hour on Sundays, for “Lassie” and “Walt Disney Presents,” the show before the “Wide World of Color”).
Free market capitalism runs on gains not reductions. If we are to rely on the market for solutions, there must be some real economic gain for reduction that is greater than cost reduction. In today’s world that would mean a sliding scale for energy that is opposite of what we have now: paying less per kWh for electricity if you use less rather than less if you use more. This certainly isn’t the “natural” order of free market, the free market relies on scarcity to increase price across the board. In Europe, they’ve increased the cost of energy “artificially” through taxes, acknowledging that the free market is severely short-sighted. In this country our gasoline taxes are going down as percentage of the cost because they are levied per gallon rather than per dollar.
To a large extent this is also biological. Natural selection has favored those in our species that have amassed wealth, first in the form of stored food, now in the form of a much broader array of material—TVs, automobiles, computers, weapons, etc.—but the future of the status quo, if not the species, relies on cooperation. Perhaps if we can get our big brains to override our reptilian ones in this regard, we’ll be able to turn around. Otherwise we may be in for the most Malthusian of population curves.
Whenever I write something like this I ask myself, “How in the world does this help?” I’m not sure. I’m a “glass half full” kind of guy. I’ve seen this kind of trend before and often it ends with an abrupt shift when there is some kind of catalytic event. So I remain optimistic that a catalytic event will preclude an apocalyptic one.
Response to Robert McClellan
Robert,
You wrote, "In "Is Efficiency Sufficient?" (prepared for the European Council for an Energy Efficient Economy (eceee) with funding from the European Climate Foundation and the U.S. Environmental Protection Agency’s ENERGY STAR Program), Chis Calwell notes that we've successfully increased efficiency, but energy loads are increasing."
In 2009, I wrote two blogs on that topic:
Getting More Efficient, But Using More Energy
The Jevons Paradox
Robert,
You wrote, “In ‘Is Efficiency Sufficient?’ ... Chis Calwell notes that we've successfully increased efficiency, but energy loads are increasing.”
The Jevons Paradox
Response to Tim Rowledge
Tim,
You wrote, "I spent approx $2,500 for the entire thing." So, if the gadget saves you $100 worth of electricity a year, will it last long enough for you to break even?
phantom loads
I've used the Insteon system (http://www.smarthome.com) in my new house with considerable success. It can substitute for already installed switches/outlets/etc if you have an existing house. It needs no central control device, though it can do cleverer things with one; which can be anything from an old PC or Mac to a sophisticated special purpose unit. Plug a power strip into one of the plug-in relays and you can turn it on/off by remote control and or timer. Have a button by your bed to turn off everything with one press.
I spent approx $2500 for the entire thing. I didn't need to worry about any traveller wires for 3-way switching - and anyway my stairwell lights have ended up with effectively 6-way, so imagine the fun of hard-wiring that! Since insteon uses the power lines as the main transmission means (though there are wireless backups as well) you only have to make sure you have all three wires at each location.
I should add that the simplest possible insteon network is two devices talking to each other to do a three-way switch. Or perhaps a wireless IR detector talking to a switch to turn on lights.
Thermal mass and shading
Calculated per square foot, the annual energy consumption seems to be 1.7 kWh/sqft for the Montague house and 3.3 kWh/sqft – almost double – for the Beaton’s house.
I constructed a passive solar house in 1982 in NJ. Supplementary base board heating and hot water heating is with natural gas. Thermostats are set at 70 F degrees for room heating and 130 F for hot water storage tank. Converting the gas consumption to kWh and adding to the metered electrical energy, the total consumption for 2011 was 7,897 kWh for 3780 sqft of living space, or 2.1 kWh/sqft. The house has extensive cathedral ceilings and the total living space volume is 55,000 cuft. The energy consumption was 0.143 kWh/cuft, which is probably a more meaningful comparison.
The main energy futures are: Solar space with thermal mass for solar heat collection, large oak trees for summer shading, additional outside wall insulation with 1 inch T&G Styrofoam board from basement foundation to roof line, Glazing with fixed panes and awning windows, facing mainly 15 degrees south-east, 24 inch roof overhang and 24 inch upper floor overhang for summer shading, AC with air handler in insulated attic room, mainly used for humidity control, whole house ventilation fan, high efficiency pulse combustion boiler with modulating heat output, energy efficient light bulbs and appliances.
Compared to the describe Passivhaus, it is not super-insulated, but has thermal mass and makes optimal use of the site conditions. Added thermal mass should be a design requirement for Passivhaus construction.
HERS & EEI
Strong arguments for the HERS and Energy Efficiency Index (EEI). A building must be climate appropriate and learn from conditions at the site. It cannot be some cookie cutter blueprint. It must be site appropriate and take advantage of the site (sun, shade, wind, water, orientation, soil, elevation)
Martin asked if my $2500 of insteon stuff would 'pay back'.
Well, it saved me some wiring costs up front, though I didn't do anything to really establish how much. How much would hard-wiring half-a-dozen multi-way switches cost? And how much to debug them later?
It's saved me extra wiring costs later when I worked out I wanted an extra light fitting and only had to get some power to the location and a relay unit; the control is done electronically and so there was no need for adding a switch and wiring up to it.
It makes combining lights trivial, which makes it very simple to turn off lights when you don't need them on, which will save some money every year. It's also a good safety thing since I can turn off the kitchen and living room lights as I enter the bedroom rather than stumbling through the dark.
It's possible to hook up your heating system as well, making it reasonably easy to do more sophisticated things than typical thermostats allow. I work at home though so to be honest it's not so important to be able to remote control the house. I do have a button set up to set the house to 'out for the day' state which will shut things down, turn on a couple of lights around dusk, stuff like that.
But no, I don't know if in strict financial terms it will pay back in 5, 10, 20 years or indeed ever. But then, without it several quite important aspects of my house would have been much harder to arrange and more expensive to build.
The electronics should get cheaper if the concept ever properly takes off and maybe one day something will be built in to all appliances. The sad thing is that 15 years ago I was working as a researcher at a lab in Silicon Valley on a project to do just that - universal networking for all appliances to provide control and data so you could just send any data from any appliance that could supply it to any other that could use it. Any video on any screen, any audio on any speakers, answer the phone with the TV speakers and a microphone, stuff like that. Every switch, every light fitting, every outlet would be on the network. Right now to get anywhere near that you need an astonishing array of differing and usually incompatible and unreliable systems. Sad.
Response to Scott Kruse
Scott,
I don't understand your point.
You wrote, "Strong arguments for the HERS and Energy Efficiency Index (EEI)." Are you praising these two buildings are criticizing them? Certainly both buildings have very low HERS Index scores.
You wrote, "A building must be climate appropriate and learn from conditions at the site. It cannot be some cookie cutter blueprint. It must be site appropriate and take advantage of the site (sun, shade, wind, water, orientation, soil, elevation)."
These aren't cookie-cutter homes, and they both take advantage of solar gain... so I assume you are praising the buildings?
"Saving Energy" with smart switches
This canard was promoted for a while by our local smart home people.
Just ask them what the standby draw is for the switches and controllers. In our case, that first elicited blank stares, then the phone number for the factory, then finally the data.
Most wired-in communicating switches, plugs, and modules use at least two watts on standby. The controllers usually use a lot more.
So, a house full of switches with a central controller probably costs as much energy as it could save.
Parenthetically, wiring six-way switches is not complicated and doesn't require troubleshooting!
