![](http://images.greenbuildingadvisor.com/app/uploads/2019/06/04175220/DuPont-Tyvek-HomeWrap-2783x1856-700x467.jpg)
When I first started to look into these products, I was using the acronym WRB to stand for “weather-resistive barrier.” It seems that “weather-resistive barrier” and “water-resistive barrier” are often used interchangeably, both by building professionals and manufacturers. However, I learned enough in my interviews with trusted building professionals to change the acronym so that “WRB” stood, more specifically, for “water-resistive barrier.”
The thing is, it’s important to be very specific about the four different control layers in a building assembly—water, air, vapor, and thermal. Unlike the water-resistive barrier, which may terminate at the top of the wall beneath a roof overhang, for example, an air barrier is a continuous assembly that must connect from one plane of a building to the next. As you’ll see, the products often can do more than just keep water out of your walls and you may be able to use a water-resistive barrier as the air barrier on walls, but that is only one dimension of the air-control assembly.
As you choose products for your work, take the advice of the building professional I spoke with and think about the four control layers individually at first. Then, if you can use a product that does double duty, great. Here are nine products that all work first-and-foremost as water-resistive barriers. Some have been around the block, others you may not have encountered yet.
DuPont Tyvek Homewrap (photo above)
For a while it seemed that the brand name “Tyvek” was used synonymously with “housewrap.” This is because it was the first synthetic product to hit the American market, long before a WRB was required by the International Residential Code (IRC). Tyvek HomeWrap is nonwoven, nonperforated, high-density polyethylene. It has a perm rating of 56, one of the highest available, and is UV…
Brian, I am researching WRB products to use on my build in climate zone 7. What do you know about Carlisle CCW 705 and Carlisle WIP 300HT? Used on the 500 year wall house built by Matt Risinger utilizing Lstiburek's perfect wall concept.
Hi Alan,
I don't know too much about them. One thing that jumped out at me about them is that they are both low-perm membranes.
While roofs tend to be low-perm assemblies, particularly if you are using asphalt shingles, on your walls, you may want something more vapor open (Matt is in Austin, TX and with the wall assembly on that house, a low perm exterior made sense). Unless you are planning, say foil-faced exterior insulation on your walls, you'd typically want a more vapor open WRB so the sheathing can potentially dry to the exterior.
Matt's an approachable guy, if you are interested in his take, he'd likely respond to you via social media or email. But again keep in mind that his climate zone is very different from yours.
I'm trying to determine whether Blueskin VP100 is an adequate air barrier on it's own, or whether the plywood seams still need to be taped. Do you know which way most people are doing it when they want very tight air barriers?
This comment was interesting: "When installing a rainscreen assembly over these products, you can use Pro Clima’s Tescon Naideck batten tape behind furring strips to create a WRB with no vulnerable fastener penetrations." So is this something that should be done with any SA when adding furring strips? I've never heard of anyone doing this. Thanks
