Building Matters
Meeting Energy Code Requirements Using the Performance Path
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes
Less expensive PV systems also allow designers of net-zero homes to specify lower insulation levels and less expensive windows. Photo credit: Martin Holladay
In my last post, I explained how the energy conservation provisions found in Chapter 11 of the International Residential Code (IRC) provide options for designers and builders when it comes to energy code compliance.
Since energy codes were introduced in the 1970s, they’ve provided different ways to design and build a home’s thermal envelope to provide for conservation, as well as other methods of creating effective use of energy that are all sufficient to meet the performance goals established by the International Code Council. Though there have always been options, the options have evolved.
The prescriptive methods for energy code compliance (including the R-value alternative, U-factor computation, and UA alternative) were explained in the last post. These straightforward requirements outlined in the IRC are generally simpler methods than the compliance paths I’ll discuss here.
In this post, I will explain the performance path and the Energy Rating Index, or ERI, but only a basic overview. That’s because these methods require third-party evaluations and significantly more detail about the house’s design, location, orientation, equipment, airtightness, on-site energy generation, and more to be evaluated for energy code compliance. While they may require more detailed information and the work of third-party professionals, they also offer much more design flexibility and choice.
No matter which path you take to energy code compliance, the 2021 IRC includes a section of “additional efficiency package options.” Here designers and builders face another set of choices. I will discuss this section of the energy code in this issue as well.
Performance path and energy costs
When measuring the results of something, you need to have a metric for comparison. For my route to the retail store, the metric of success is whether I arrived. But when measuring the path of energy code compliance, there is…
  1. anonymoususer | | #1
    Thank you for this informative piece. Roofers, I will take this opportunity to ask a question not about the article content but rather the roof: i notice the roof shown has asphalt shingles on higher facets vs metal standing seam covering porch. On New England houses this pattern is or has become popular. Im curious why ? Why wouldnt builder spec same cladding for all facets? If entire cladding is standing seam, upfront cost is higher but reroof can be delayed almost perpetually. If all asphalt, upfront cost lower but reroof needed sooner. Lower facets of roof get water shedding from higher ones. Why the asphalt / standing seam combo ? Why not be economical now and get all asphalt OR blow the big bucks now for 100% standing seam ? Thank you
    1. Malcolm_Taylor | | #2
      am,
      It's entirely a design feature to add some visual variety to the house, and include what is seen as a higher quality finish. Like the photo, around here it is invariably a small porch roof or dormer. Leaving the main roof as shingles both saves money, and allows the house to fit in with its neighbours.
