In 2008, Hurricane Ike rolled over the Texas Gulf Coast destroying over 90% of buildings in Gilchrist, Texas. Ten years later, Hurricane Michael’s route through the Caribbean and over Florida left behind wide-spread devastation estimated at over 25 billion dollars. The two homes pictured below were built to survive these catastrophic Category 5 hurricanes, something that clearly can’t be said for many of their neighbors.
While both homes included materials and techniques in their construction that might have been above and beyond standard codes, they also used readily available products such as hurricane-rated impact windows and doors intended to meet the more stringent requirements in their locations.
Glass thickness and interlayers
Impact-resistant windows typically have a structurally reinforced frame and sash, heavy-duty hardware, and laminated glass. Given all laminated glass—and tempered glass—is impact-resistant to a greater or lesser degree, what makes the glass installed in windows intended to meet hurricane-resistant standards special?
As mentioned in Part 1 of this series, the interlayers used in laminated glass can vary in thickness depending on application; .030 in. for safety, .060 in. for security, and .090 in. for impact resistance is a broad generalization, but it is a reasonable range to use as a guide.
Hurricane-impact windows typically have laminated glass constructed using interlayers made with either polyvinyl butyral (PVB) at .090 in. or SentryGlas (SG) at .095 in. There are laminated glass options in both thicker and thinner variations, plus a few options using interlayer materials other than PVB or SG, but they are niche products that won’t be addressed here.
While the interlayer thickness required for impact laminated glass is fairly consistent at .090 in., the glass used can vary from 2mm to 6mm or even thicker, depending on location and application. (While the interlayer is most often presented as decimal inch, glass…
