![](http://images.greenbuildingadvisor.com/app/uploads/2018/07/24200917/_DSC0003%20%281%29-main-700x650.jpg)
Image Credit: Scott Gibson
About to start a new house in Climate Zone 5, Nicholas C is working out the details of how to insulate the basement slab and foundation walls. There is more than one type of rigid foam insulation he could use, and it could be applied on either the inside or outside of the foundation.
For a couple of reasons, he’s planning on 2 inches of extruded polystyrene (XPS) beneath the slab rather than expanded polystyrene (EPS). The XPS would perform better in a wet environment, Nicholas says, and Owens-Corning, one insulation manufacturer, claims it no longer uses a “bad” blowing agent.
He’s not had much luck in tracking down a local supplier of Type II EPS, while XPS seems much more available.
“If I have the option to get EPS Type II, I want to know if I should use it or XPS for my foundation walls,” Nicholas explains in a Q&A post at GreenBuildingAdvisor. “This is a walkout basement, meaning one wall is completely below grade, one wall is half-and-half, one wall is completely exposed, and the other wall is conveniently below grade because the garage is on that side, so it has dirt beneath it but also less exposure to elements since it is also the garage stem wall. “
He also wonders whether he should hold off on installing insulation on the outside of the foundation walls now and tackle that project from the inside as a retrofit a few years down the road.
Those related questions are the start of this Q&A Spotlight.
Waiting is not a legal option
Whether Nicholas chooses XPS or a dense form of EPS, he has to choose something, replies GBA senior editor Martin Holladay.
“I’m not sure about code enforcement in your area, but in Climate Zone…
How to Insulate a Foundation
How do you writers find this disinformation, and then never check it out for accuracy before puublishing? People who have even half a brain will start to not trust any information on this website. Education on the proper use of construction grade foams needs to be addressed by the educational and scientific people before we have every idiot following these unresearched misleading articles.
Response to George Hawirko
George,
Here's my advice: if you are going to accuse GBA of publishing disinformation that has not been checked out for accuracy, it would be appropriate for you to mention at least one statement in the article that you deem to be inaccurate.
Absent that, it's hard to assess your opinionated posting.
