![](https://beta.greenbuildingadvisor.com/app/uploads/sites/default/files/images/1.gif)
Video Transcript:
Working up in an attic is absolutely no fun at all, especially on a hot day. But this kind of work has to be done. Plumbers and electricians end up putting a lot of holes between the inside of the house and up into the attic, so sometimes we even end up with holes with no wires in them that have never been sealed up. And of course when those guys drill their holes, they always drill a 1-in. hole for a 1/2-in. wire. We’ve got to fill those gaps up.
Choose the right sealant for the job. That insulation has turned gray or brown, and that’s due to the air leaking out of those electrical holes, by the wires, and up and filtering through the insulation, depositing the dust — 24/7, 365, year after year. So, even though they’re really small holes, they add up to a big air leak over time. In some jurisdictions, these penetrations require that we use a fire-blocking type of sealant — either a fire-block caulking like this, or a fire-rated foam type of sealant. The caulking is good for real small gaps, but because we’ve got a pretty good-size hole, even around the wires, we’re going to use a spray foam that can expand around the wires and completely fill that void. Another option: if you have this for sealing the top plates of the walls to the drywall, you can use acoustical sealant as well. All three are good choices. I’m going to use the spray foam.
It’s easy to do a good job. What I like to do is push the probe down through the blocking to the top plate of the wall, about 2 1/2 to 3 inches, and then I’ll…
Great Stuff fire blocking
Great Stuff fire blocking spray foam is not fire rated at all in fact it like any other Great stuff foam can com-bust if exposed to 240 degrees?- per the cans printed information. The only difference is it is colored orange. Fire block instead would be mineral wool insulation ....
Reply to Tim
Reply to Tim Miller:
According to information provided by Dow Chemical, Great Stuff Fire Blocking foam is "Recognized as an Alternate Fireblocking material for residential construction. Tested according to ASTM E84, ASTM E814 (modified), UL 1715" It is also listed in Dow's ICC-ESR # 1961 where under section 2.0 "Uses" Great Stuff Fireblock (and several other Great Stuff products) is "recognized for use as an alternative to the methods prescribed by the code for maintaining integrity of penetrations of fireblocking."
It's ultimately up to the local building and fire officials to approve alternative methods not prescribed in the building code. So verify if local building codes require specific measures for fire blocking and if officials accept individual ICC-ES reports before using a fire blocking methods and materials. Also, the use depicted and described in the video is residential construction and does not correspond to commercial construction.
