As much as 60% of all household water consumption can go to outdoor uses. Irrigation systems should be designed not to waste potable water. A good system delivers water efficiently at the right time. Systems that distribute water indiscriminately, like lawn sprinklers, are inherently wasteful.
While lawn and garden work are tempting DIY projects, a certified pro can help you accomplish your water conservation goals more efficiently. At least they can help you make better choices when designing the system.
The Environmental Protection Agency has a national list of irrigation professionals who have completed a certification process through the EPA’s WaterSense program.
—_This GREEN BUILDING TIP is from our Strategy Generator. Build a tip sheet
for your green building or remodeling project under the Strategies & Details tab._
Green points
LEED for Homes: Up to 4 points for high-efficiency irrigation systems.
NGBS/ICC-700: Up to 10 points for efficient irrigation (801.7); up to 8 points for rainwater harvesting (801.8); 2 points for irrigation zoning (801.9); 4 points for smart irrigation controller
-OR-
15 points for no irrigation system with green landscape plan (801.10); 5 points for gray-water irrigation use (802.1).
Learn more in the Green Building Encyclopedia:
LANDSCAPE: NATIVE PLANTS AND SOIL
From the Green Primer
What is Xeriscape, and why is it important?
