Encyclopedia
  • Green Basics
    How to Replace a Roof
    Replacing Roof Shingles: This video shows how to strip old asphalt shingles off a roof and how to install new asphalt shingle roofing.
  • Green Basics
    How to Install Exterior French Doors
    Exterior French DoorsA veteran remodeler shows you how to install and adjust hinged double doors for smooth operation.
  • Green Basics
    Tile a Barrier-Free Bathroom
    How to create a roll-in shower: Master tile setter Tom Meehan combines a time-tested mortar base with a modern waterproofing membrane and a linear drain to create an easy-access shower.
  • Green Basics
    Understanding Blower Door Tests
    Blower door tests reveal the rate of air leakage in and out of a home
  • Green Basics
    Adding Blown-in Fiberglass Insulation
    Increasing the R-value of your attic insulationLess dusty than cellulose, blown-in fiberglass increases R-value and installs quickly.
  • Green Basics
    Inspecting Old Houses
    Home Inspection Basics: This video series shows how an inspector identifies problems in a vintage home
  • Green Basics
    Stop Ceiling Fan Blade Wobble
    In this video, Fernando Pages Ruiz shows you how to balance the blades of a ceiling fan to eliminate wobble.
  • Green Basics
    How to Replace an Old Entry Door
    Best Practices for Installing a New Entry Door: Replacing a weathered or inefficient entry door can have a great impact on the comfort, appearance and value of a home.
  • Green Basics
    Passive House video — Episode 5
    In “Installing High-Performance Windows,” the fifth episode in a series of videos on a Passivhaus project, the crew installs triple-glazed Makrowin windows from Slovakia
  • Green Basics
    Passive House video — Episode 4
    In “Framing for Efficiency,” the fourth episode in a series of videos on Passivhaus construction, the framing crew erects double-stud walls
