Image Credit: Robert Benson — Robert Benson Photography
Image Credit: Robert Benson — Robert Benson Photography In addition to being energy efficient, the education center is a "beautifully designed, natural light-filled building that echoed rural Maine forms in a crisp, warm and contemporary way," NESEA said.
Image Credit: Robert Benson — Robert Benson Photography Recipients of the 2013 Zero Net Energy Building Award were honored at the Building Energy 13 conference in Boston. [Photo credit: Matthew Cavanaugh]
Image Credit: Matthew Cavanaugh
An 8,200-sq. ft. education center at the Coastal Maine Botanical Gardens has won the 2013 Zero Net Energy Building Award from the Northeast Sustainable Energy Association (NESEA).
The Bosarge Family Education Center was designed by Maclay Architects of Waitsfield, Vermont, and Scott Simon Architects of Portland, Maine. The center was built by Bensonwood of Walpole, New Hampshire. Andy Shapiro of Energy Balance was the energy consultant and Thornton Tomasetti of Portland, Maine, was the LEED consultant.
“Not only did this northernmost building achieve net zero energy in a challenging climate with the most heating degree days, it was also pre-assembled primarily off-site,” NESEA said in announcing the award. “The building’s impressive airtightness levels are a testament to the builder, Bensonwood of Walpole, New Hampshire, the design team and the process. It also brings great hope to the industry which has relied mostly on custom, site-built and intensively resourced structures in order to achieve such energy performance levels.”
In addition to delivering high performance, NESEA said the center also is a “beautifully designed, natural light-filled building that echoed rural Maine forms in a crisp, warm and contemporary way.”
The botanical gardens are located in Boothbay in Maine’s midcoast region.
The center has a 45-kW photovoltaic system
Features of note:
- Above grade walls insulated to R-40 with dense-pack cellulose in an 11 7/8-in. I-joist cavity.
- Roof cellulose insulation of R-60 in 16-in. deep I-joist cavities.
- Nanogel-filled and triple-glazed skylights.
- A Mitsubishi air-source heat pump for heating and cooling.
- A total of 237 photovoltaic panels, 135 on the roof and another 102 on the ground, with a total rated capacity of 45 kW. Estimated annual output is 47 kWh.
- High efficiency lighting.
The Zero Net Energy Building Award recognizes the “best” net-zero building in the Northeast. “By ‘best’ we mean one that offers not only efficiency but ideally also comfort, affordability, reliability, and elegance,” NESEA says. The award comes with a $10,000 cash prize.
5 Comments
Unbelievable...
So in other words, an Education Center of 8,200 sf with R40 walls, R60 Roof, triple glazed windows and high efficiency lighting NEEDS a 45kw system to educate PV Salesman on how to up sale PVs to homeowners?... and then they win an Award and $10K?
Maybe they need to share it with the people in KS to educate them in Sustainability!!!
Response to Armando Cobo
Armando,
Maybe I'm being dense, but I'm not sure I get your point. Are you saying that a 45-kW PV system seems to be excessive to meet the needs of an 8,200-square-foot education center?
Big time excessive
I would assume that their building has a pretty good building enclosure and their heating an cooling loads are really low. Add to that lots of natural and efficient lighting, even for NE, I find that 45ks system is at least twice as needed; unless they are installing several Ecars charging stations or getting lots of credits, like that one house a few weeks a go y’all blogged about. If we can do Net-Zero in the SW for about 1w/sf, do I think one needs 4.5w/sf in NE? NO!!!
Solar radiation in NE is about 66% of the SW: http://en.wikipedia.org/wiki/File:Us_pv_annual_may2004.jpg
Armando,
First of all, I doubt that you know the types of educational displays or educational equipment included in the building. (I don't.) So it's hard to judge its energy consumption by comparing it to a house.
Second, Maine gets about half the insolation per square foot that New Mexico or Arizona does.
Here is some more information on the Bosarge Family Education Center: "This super efficient building envelope, designed by Maclay Architects and Andy Shapiro of Energy Balance, provides a 50% reduction in building energy usage from code, and results in a modeled energy intensity of 19
kbtu/sf-yr. On average, LEED Platinum construction achieves a 30% reduction in building energy usage. A 45 kW PV array is installed to provide 100% of the energy required to run the building."
Fair enough.
Beyond Ecar chargers and extra credits, I should have included additional equipment, displays, pools & Jacuzzis, welders, 50 plasma TVs; yet still, NM Solar Radiation averages 6.0 kWh/m2/day and Maine is 4.5 kWh/m2/day or 75% of NM. IMHO, that tells me, a. their building enclosure is not as tight, b. they do have a lot of displays and stuff or c. oversized (leaning to)
